Question about Dyson Vacuums
Hose extension tube will not fully go down after use (the hard tube seems to be stopped). Have lost manual - is there a way of taking hose base out to check for blockage. It is a DysonDC15 bought October 06
Keep ur tube, wand very straight. then there should be two side buttons, press them and the tube SHOULD gently slide down.
Ive expierienced the same problem!
Posted on Feb 22, 2011
My Dyson 41 has just started only sucking through the tube
We've had our DC41 for 4 months now and suddenly noticed no suction at the base as well. Base motor works fine.Thought I'd take one last look before sending in for repair. At the base of the attachment hose near the motor is a small red tab. I depressed it and pulled the entire hose off the motor. Sure enough inside was a eyeliner pencil our daughter had unknowingly vacuumed up. I couldn't see it just peering the length of the hose. Even with a flashlight. You don't see mention of the small red tab but it allows you to see close up rather than peering down the hose if something is lodged near the motor. Apparently this pencil prevented the internal hardware to switch from wand to base suction when the handle is reclined in floor vacuum mode. These vacuums have strong suction and they will pull up the oddest things! Hope this helps!!
Aug 14, 2012 | Dyson Dc 41 Ball
Dyson dc27 (not ball version) extension wand will not release from the body. Have had the the vacuum cleaner for a year and it has been fine until now. Have tried disconnecting aluminium tube from the hose...
Sorry to hear you're having difficulties with your DC27. If the wand is jammed, it's likely that the hose was twisted when you replaced the wand on the cleaner the last time you used it. It's easy to rectify:
  • Pull the wand up as far as it will go
  • With the rear of the cleaner facing you, follow the hose down to where it attaches at the base of the machine
  • Grip the section of loose hose and pull it away from the cleaner
  • Holding the loose section of hose out of the way, pull the hose release tab
  • With the base of the hose detached from the cleaner, allow the hose to straighten itself out
  • Reattach hose to cleaner
You should find following these steps untwists the hose, allowing the wand to move up and down without restriction. However, if you need further assistance, please get in touch with us free so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 01, 2011 | Dyson DC27 Bagless Upright Vacuum
Loss of suction
You may have a colg in the power nozzle of hose. Disconnect the hose and drop a quarter through it.
Bob
http://evacuumstore.com/
Mar 27, 2010 | Kenmore Progressive 35922 Bagged Upright...
The wand is hard to pull up
The wand on this machine get lots of tiny dirt and fine dust caught in the sliding tube that fits in the hose. You will need to take the hose at its cuff end where it meets the wand and press the two tabs to release the wand out, then take some spay cleaner of any kind and wipe down the wand tube. This should make it easy to slide in and out of the hose. Now just put it back together.
Dec 10, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Hose is not getting any suction
when vacuums shut off randomly it usually means they are overheating. this can be caused by a clog somewhere in the line of suction, or, perhaps due to a very dirty filter - either way, the motor is working hard and getting too hot.
try removing all the various tubes and parts along the suction route and checking for clogs (a flashlight might help too). also, have you rinsed out your two pre-filters lately as recommended in the Dyson manual? it might help.
Apr 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ive got a sock in the tube
remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Nov 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Nov 15, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Can't get any suction through the hose.
you will see a tube coming out of the top of the base.thats where the hose attaches.but before you putthe hose on turn on the vacuum and see if you have suction at the tube coming out of the top of the base.also check and see if the brush roller is turning when vacuum is on.there is a little door you have to lift up when you attach the hose.hold the door open and attach the hose.i hope i was of some help to you.please leave feedback
Mar 21, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Part for entire hose including the connection to the water out take.
Looks like you have to replace the complete hose asm. part #90001336.
Mar 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
132 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
