Question about HP DeskJet 6988 Printer
Not sure how to feed the envlope into the printer
  • 657 Answers
Follow these steps to use the photo/envelope feeder for single envelopes:
1. Insert the envelope into the photo/envelope feeder with the side to be printed on
facing down and the flap to the left.
Push the envelope into the printer as far as it will go without bending.
3. Slide the photo/envelope feeder forward as far as it will go.
Thank you for using Fixya
Posted on Oct 08, 2009
Print envelopes
Are you using the tray 1 manual feed for the envelopes? If it was working for you before but now has trouble feeding from that tray you are probably going to need a new PU roller and sep pad. You can try and clean the roller with a lint free cloth and use isopropyl alcohol.
Sep 02, 2014 | HP P2035N LaserJet Monochrome Printer
Do you have print out step b step instrution sheet that tels you how to print envlopes from a brother MFC-8890DW
HOPE THIS HELPS YOU... http://www.retrevo.com/support/Brother-MFC-8890DW-Multifunction-Printers-manual/id/23331dj580/t/2/
PLEASE VOTE.. THANKS.
May 18, 2011 | Brother MFC-6890CDW Printer
I need tray 2 to be the default setting for this printer. It always reverts back to tray 1 everytime I try to print.
Paper Handling Issue -
Hit Menu
Arrow down to Paper Handling and hit the green check
hit the green arrow to go into Tray 1 size - arrow down to envlope #10 hit the green arrow to save
arrow down
hit the green arrow to go into Tray 1 type - arrow down to envlope hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 size - arrow down to letter/legal (depends on what your using) hit the green arrow to save
arrow down
hit the green arrow to go into Tray 2 type - arrow down to plain (assume that your using plain paper) hit the green arrow to save
also pull out the paper tray and confirm the guides (where you can adjust from letter to legal etc)
is set correctly.
That should take care of it unless the document you are tring to print is a different type of paper size.
Oct 19, 2010 | HP LaserJet P3005n Printer
My HP printer is not feeding paper.
Here is the solution for your problem just go through the steps given below and you can fix it yourself.
1. Check to make sure your printer has paper in its paper tray. If your printer has paper, check to make sure that the tray is not overloaded. If you suspect your paper tray is overloaded, remove some paper from the tray and attempt to print again.
2. Use the same type of paper when stocking the tray with paper; do not mix different types of paper into a single stack. Mixing different brands and weights of paper in a single stack makes your printer more prone to paper feed problems. If you find that one particular type of paper causes consistent feed problems, switching to a different type or weight of paper may solve the problem.
3. Check to make sure the paper in the tray is whole. Torn and creased paper will cause problems with the printer.
4. Open your printer's rear access cover and inspect the paper feed rollers. Dusty or dirty rollers cannot grip the paper; clean them with a soft, damp cloth and water.
5. Count your printer's rollers. HP printers have six paper feed rollers; if your printer is missing rollers the paper will not feed correctly. Contact HP to replace the rollers and repair your printer.
Thanks.
Oct 06, 2010 | Computers & Internet
Paper feed
Make sure your paper is not curved. Fan the paper and make sure it sits in the hopper evenly. Also make sure that when you were installing the printer you did not drop something or a piece of the packaging is not stuck in the side. Use a flash light to inspect the paper path
May 28, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
Paper wont feed
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
Apr 24, 2009 | Office Equipment & Supplies
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
What does the light mean?
the ! in the triangle means manual feed or "continuable error" which means that the printer is manual mode. or there is a paper feed problem.
you need to check the HP print software, make sure all the printer setting are correct.
if so, then check the printer paper tray, make sure they are in working order, and there is no paper jam on the paper path from the tray to the output.
The manual feed use different paper path, so check the tray path.
then unplug the printer from the computer and shut down the printer.
wait 2 minutes, power up the printer and connect the printer tot he computer.
Dec 16, 2008 | HP LaserJet P2015dn Printer
New Kodak 5300 All In one Problem
tell it a3 envlope ok a5 in settings to print envlope an dyou size ok thx nick
Feb 03, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP DeskJet 6988 Printer Logo
309 people viewed this question
Seeker5211
Seeker5211
