Question about TallyGenicom Tally 5040 Passbook Matrix Printer
TallyGenicom 5040 printer not detected by computer. what is the problem?
    Scholar:
  • 127 Answers
Check if your signal cable is working correctly and if the drivers have also been installed right.
thank you
wonder
Posted on Oct 08, 2009
Paper jam error
wash the feeder rubber & clean the sensor of tray unit.
Dec 30, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
How do I get Tally T5040 passbook Printer driver?
Check the manufacturers website (dascom.com):
http://www.dascomamericas.com/Support/Default.aspx?type_id=3&info_id=5&itemid=23&name=T5040&act=4
Jan 07, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
May 25, 2012 | TallyGenicom Tally 5040 Passbook Matrix...
Where to find tallygenicom 5040 driver
http://www.tallygenicom.com/products/productdrivers.aspx?id=5990
Best, Hunter
Mar 02, 2011 | TallyGenicom Office Equipment & Supplies
How to install tally genicom 5040 driver
Have you tried removing the current printer and installing the printer again using the current driver on Tally's website? http://www.tallygenicom.com/products/productdrivers.aspx?id=5990
If this does not work, can you elaborate on the "problem" you are experiencing?
Best, Hunter
Mar 02, 2011 | TallyGenicom 5040 MSR-H - Passbook - B/W -...
Upgrade firmware from 1 to 2
Hi there
This is only the driver you need to update it because it not see the fonts, and if you have the new windows Vista or Windows 7 then this driver you have now not work, you need the right deivers for it
Feb 14, 2010 | TallyGenicom Tally 5040 Passbook Matrix...
Our 5040 tally printer is not being detected by a computer running on Xp and we have tried both parallel and usb cables.
I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
Details on entering the Menu on the 5040 can be found on the Dascom web site; http://dascom.firma.cc/support2/technical_notes/serial_matrix/5040/5040_tn004.htm
Oct 08, 2009 | TallyGenicom Tally 5040 Passbook Matrix...
Tally Genicom Slow Printing in Foxpro Dos Program
change the connecting cable serial or parallel what you have it may help you.
Jun 15, 2009 | TallyGenicom 2280 Matrix Printer
Tallygenicom 5040 passbook printer problem
Right, the problem lies in these triangles. They're part of what's called "lower paper feed unit" and are drien by an electromagnet to start/block when needed. This magnet has a tiny problem letting go, so the triangular wheels stop in wrong positions, blocking the paper. The best solution is to change the "clutch" with the latest UCL version (3), you'll know it for having aluminium toothed wheel rather then plastic ones.
Jul 16, 2008 | TallyGenicom 2280 Matrix Printer
TallyGenicom Tally 5040 Passbook  Matrix Printer Logo
478 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
