Question about Whirlpool Refrigerators
I have a whirlpool custom series frig & the bulb has gone out. After switching it with 2 new bulbs with no results, I wonder if there is an electrical problem? Additionally, what appears to me to be wiring that seems to lead from the bulb box to a box in the back of the frig has started to make a "ticking" noise. Can YOU HELP? KariAnn
    President:
  • Whirlpool Master
  • 1,922 Answers
Yes KariAnn,
I have replaced 3 of these this week already, its the control box,lower left corner inside white plastic box, when light bulbs blow out it surges& the control board is ruined, its quite common, replace it with a new board no need to replace the cover or box with a new one, go to appliance parts pros or call 1-877-477-7278, the cost will be about $85.00 with shipping included, UNPLUG REFRIGE FIRST, and remove control board(2screws) on back of refrige, take off plastic cover and unplug 3 wire harnesses and install new board put cover back on and its good to go......if you have any other questions I'm at dmftrucker@yahoo or 24/7 Appliance Service (608)214-5632....Regards Daniel
Posted on Nov 03, 2009
The light has gone out.
make this test and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Whirlpool Microwave Ovens
Hit the bulb and bulb blew Is there a fuse? new bulb doesn't work either
Have you checked power to the lamp from the switch? Wiggle the switch a few times and see if you get a flicker
May 15, 2012 | Washing Machines
Inside light went out...replacing bulb did not work, any help or advise? thanks! Mike
Many times when the inside light fails to operate...it could be:
(1) A bad bulb ...replace with a known good one.
(2) Bad connection of the light bulb in its socket.
(Remove the bulb and spray the socket with WD-40 Spray Lubricant) then...
(3) Replace the bulb with a known good bulb..use a dry rag to securely tighten the bulb in its socket.
(4) The "Door Switch" could be bad. Replace bad "Door Switch" with new one.
Hopes this helps....Good Luck! ...... HandyHenry
Mar 24, 2011 | Whirlpool Refrigerators
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Light wont burn in frig
Have you checked the bulb or the light switch?
Jul 18, 2009 | Refrigerators
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Changed bulb in frig and light still not on. Frig is older whirlpool. est age is 15 years. i thought bulb was just burnt out. everything else still working. replaced old bulb 15 w with an "appliance" bulb...
I would stick with an appliance bulb. The glass in those is more resistant to extreme temperature changes.
Your problem sounds like it could be that the door switch has burned/corroded contacts.
If you have a continuity meter you can remove the switch and test it to see if it's working.
BUT, FIRST, TURN OFF THE BREAKER TO THE FRIDGE!!!!
If you don't get continuity thru it, soak it in rubbing alcohol for about an hour. Let it dry for about an hour, and test it. If it's still not working, replace it.
If you need help with the continuity testing, let me know.
Apr 30, 2009 | Whirlpool ET8MHK Top Freezer Refrigerator
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
Looking for replacement parts for vector spot light
The bulb you are looking for to fit these vector spot lights is an automotive bulb, and H3 with a PK22s base. They come with a cable and a nickle size disk at the base of the bulb. They come in several wattages, eg 55w and 100w. Try the "bulbs.com" website, in their search box type "H3 PK22s" and you will see they have a variety of wattages and voltages. Be sure you buy a 12V for these spot lights. They come with a cable and nickle size disk at the base of the bulb. Hope this helps. From Uncle Ray
Oct 06, 2008 | Camping, Backpacking & Hiking
Refrigerators Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
