I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
There are 3 issues:
1)When I scan a document and select it into Microsoft Publisher, the document...
(More)
There are 3 issues:
1)When I scan a document and select it into Microsoft Publisher, the document appears very blurred and slightly green as far as the text is concerned.
2) Also, it does not set text boxes where
they are placed.
3) The document in Publisher seems 100% the size it should be, but in "print preview" the document seems smaller and it in fact prints smaller.
I have an OKI C5400 and I keep getting a paper jam in the front of the printer. I have replaced the...
(More)
I have an OKI C5400 and I keep getting a paper jam in the front of the printer. I have replaced the fuser, thinking something was stuck inside, cleaned the rollers in the front of the machine, ran paper manually through the rollers to catch any loose paper and have taken everything (toners, drums and belt) out of the machine and cleaned and replaced. Any ideas that I can try?
