Question about Konica Minolta magicolor 2430 DL Laser Printer
Light printing I received an exchange printer, and after switching the toners, etc., the replacement prints VERY light. It does print well except for the lightness. The toners are displayed as 96% remaning and the drum unit 100%. Any help appreciated. Thanks, Norm
  • 42 Answers
I would suggest using the printer's menu and checking both Direct Print->Print Quality and Direct Print->Brightness as these may be set too low or too high. Change these values, 1 at a time, and do a test print to check the print density
Posted on Dec 24, 2007
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
I tried printing a document, and it printed all the pages except for the last page. I have tired to repeatedly print the last page and it will not print. The toner light is on, so does that mean I have...
first of all maybe your file has a problem. DO NOT CHANGE your toner. Try to print only last page, or copy the content of the last page in the new document and the print it. Sometimes the printer can not recognise some files correctly and that is the major problem
Feb 18, 2011 | Brother HL 2140 Laser Printer
Hp 2840 was printing light in black, so I replaced the cartridge, did a clean run print from tray 1 & now it only prints 1/2 a page from top to bottom. I shook cartridge installed again turned the...
Dumb question. Did you pull the strip from the toner cartidge? OEM or aftermarket? I would try the old cartidge and see if it changes if you don't have the old cartridge anymore I would contemplate replacing the one you just purchased or taking it back to where you purchased it and get an exchange for a defective cartridge.
Feb 10, 2011 | HP LaserJet 2840 Printer
In samsung scx 4x21 all-in-one, fax received but not printing. "memory received" we get in display panel.
your toner is empty refill or replace it. You can continue printing when the toner is empty but the faxes recieved will not be printed till the toner empty light is reset.
Feb 07, 2011 | Samsung SCX-4216F All-In-One Laser Printer
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Replaced toner cartridge but toner light and status light stay on. printer still not printing
turn off the printer and cacel all the documents from print spooler .and switch on it.
Oct 26, 2009 | Brother HL-5240 Laser Printer
Toner light and error light steady
Remove the toner and shake GENTLY left to right - NOT over your rug or clothes, etc.. shake it lightly from side to side over a garbage can.. what that does is settles the toner and spreads it out so the printer thinks it is not empty.. if that removes the light, keep printing, shaking, printing until you cannot remove the light.. then buy another toner.
Jul 07, 2009 | Dell 1710n Laser Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
761 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
