Question about Eltax Audio Players & Recorders
Eltax logic 8 system wont work even when the switch light is on behind
Eltax Atomic A-8 A8 Active Subwoofer i have a burnt out power transformer
Power transformers are safety parts and should only be replaced by the same type or one specified by Eltax the maker. You should contact them for the spare parts department or the place that stocks them.
Jun 01, 2013 | Audio Players & Recorders
How to setup an eltax surround system? what exact place do I put them (also behind me)? It contains 4 speakers, 1 sub-w, and 1"tweeter/high range" to put on your tv. I thank You sincerely!
Well, that is pretty dependent on the room size and seating position. Ideally the center channel should be directly under the TV. This is where 90% of the dialog will come from. The two tall speakers should then be placed adjacent to the TV, preferably a couple of feet away. The smaller surround sound speakers should be approximately ear level, to slightly above and behind the viewer. The surround speakers are bipolar, so they will radiate sound out of each side, therefore you do not need to "angle' them towards the listener. The sub woofer doesn't really matter, the bass frequencies are non-directional. I like to hide it under a table or something like that.
Some new receivers have built in surround set up programs that will send a test signal to each speaker and "listen" then adjust the delay and volume accordingly. Without that it will take some trial and error to get any system dialed into the perfect settings. Then what may be ideal for one specific location will sometimes not sound as good from another in the same room.
Good Luck.
Dec 24, 2010 | Eltax Chroma 5-Pack System
Samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Jul 07, 2010 | Samsung HTC550 Theater System
Watching television or a film my Eltax Atomic a-8.2 subwoofer cuts in and out whenever it feels like it! you can hear it click then the bass cicks in then, even when you know there should be some bass...
most active subbs are desinged to shut off untill they are needed ( extreem bass injection) then they come on try setting your sensitivity to low or off
Jun 18, 2010 | Eltax Atomic A-8.2 Subwoofer
How can i conect it at 8 ohm?
To what????
They're spec'd at 8 ohms. What's the specific question regarding that?
Jun 06, 2010 | Eltax Monitor III Main / Stereo Speaker
My brake lights wont work but my blinkers work and the backup lights also work what could the reason why my brake lights wont work?
check fuses for brake system.also check brake switch under dash behind brake pedal. disconnect plug from brake switch and use a jumper wire to jump across plug to activate brake lights. if your brake lights come on remove switch and install new switch. hope this will help.
Apr 20, 2010 | 1984 Dodge D150
On my f150 the reverse sensor turns off when i start backing up. the dash switch stays in off mode even when pushing it.
Did you check Fuse #18 ?
Check behind the bumper for corrosion on the parking aid sensors.
Some times the sensors get corroded, and this can lead to a shut off on the system.
Oct 27, 2009 | 2006 Ford F-150
00 CBR F4 brake lights dont come on when applied
Have you tried powering the brak circuit itself at bulb. If it comes on then you need to find broken wire between light and switches. Since neither work if you can trace to where they meet break should be behind that.
Aug 20, 2009 | 2000 Honda CBR 600 F(4)Y
DVD draw refuses to open
there is a hole in the middle or to the side of your player. get a paper clip and stick it, go in slowly, and push. it should come out.
Jun 16, 2009 | Eltax Televison & Video
The ventilation fan of my power inverter wont shut off
This is hard without knowing the specifics, but these fans can be wired to be on all the time, or controlled by the thermo-switch, or even electrically controlled by a logic board. You may have a stuck Thermo-switch or a bad logic board, since to fail shorted is the standard failure mode (for a Triac).
Nov 16, 2008 | Electronics - Others
69 people viewed this question
Top Eltax Audio Players & Recorders Experts
Trippy Tripp
Tom Chichester
Bill Willard
Bill Willard
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
