Question about D-Link AirPlusG DI-524UP Wireless Router
Cannot connect laptop to wireless. Apparently my password is wrong (even though I am sure it is not). Have tried to reset wireless router (D-link DI 524) without success.
  • 2,260 Answers
Make sure that the password that you have is correct if not then you will need to check the password of the wireless network.
Click Here for more info about wireless network.
Posted on Oct 08, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
Cant change router password,dont know how
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 25, 2011 | D-Link DI 514 Wireless Router (DI-514)
My iPhone 4 will not connect to my wireless router EVEN THOUGH I'm using the correct password. It tells me it is the wrong password. All other devices (netbooks, laptops) connect with no problem.
There are 3 things to try:
1: reset router
2: on iPhone, Settings, General, Reset, reset Network Settings.
(this erases all saved network settings, if you use other wifi, you will have to set them up again in the iPhone)
3: Change the password on the router, try to use a 13 character password if possible, as this seems to sometimes help.
If all that doesn't work, then you may have an issue with the phone itself.
Sep 08, 2010 | D-Link DIR-615 Wireless Router
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Jun 13, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cannot connect to my D-Link AirPlus Xtreme G DI-624 wirelessly
In case like this one sometimes it is best to reset the password then try to connect each of the devices.
The D Link 6 series router where good but a little tempermental at times. Also you could check the Dlink site for new firmware as from time to time manufacturers make improvements even after the product has been to market.
Sep 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I forgot my username and password and want to create a VPN or remote connection
If you've forgotten the username and password, there is really no viable solution other than resetting the router. All the software can be found on linksys' website, along with manuals for reconfiguring your router. Breakout your trusty paperclip and press the reset button on the back of the router. Reconfiguring should only take a few minutes. The default username will be "admin" and the default password is "password" (both without the quotes.)
Manual
No software is actually required to install the router. Any information needed will be in the manaul, provided above.
Hope this helps!
May 29, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I reste my password?
hello have you turn the power off and press the reset button on the back of the router press it for 30 seconds good luck
shaun
Feb 05, 2009 | D-Link AirPlus DI-524 Wireless Router
New laptop
By default your D-Link router will configure inside port to 192.168.0.1 with subnet mask of 255.255.255.0. Default username is admin with no password. You should try that first. If it doesn't work you can reset your router to a factory defaults:
1. Leave your device powered on
2. Press reset button with the paper clip (it located next to a power connector)
3. Keep button pressed for 10 seconds
4. Release the button.
Try to connect to your router again.
Good luck.
Feb 27, 2008 | D-Link DI 514 Wireless Router (DI-514)
Cannot connect my lap tp to the internet via my d link router on my desk top
Please indicate which is your issue.
Is your issue with the router's administrative password to used to configure the router?
Please confirm your router's manufacturer and model number.
IF not go to Wireless Configuration
If the router needs to be reset (because of an unknown password) do you know the proper settings to reconfigure the router? If not or even if unsure please provide your Internet Service Provider's name so we can get accurate instructions before proceeding any further on this password issue.
Is your issue with the passphrase/password for a wireless adapter to access a secured wireless network using either WEP or WAP encryption?
Do you have another wireless computer that works? -- you may be able to find the passphrase in the configuration of that machine's wireless adapter avoiding the need to have the administrators password for the router for the time being.
Dec 13, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlusG DI-524UP Wireless Router Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
