I have a Samsung rear projection HDTV model # HCM4215W and it does not have a picture. it is a black screen with the timer LED blinking. I do not hear it trying to power up. It seems like it may have a bad Amplifier or module to power up the unit???
  • 19,396 Answers
Hi.
Your TV went in stand by and does not wake up because an internal fault had been detected, and now the TV is in protect mode.
If after the fault the TV went in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages are shut down to prevent further damage.
Only +5V low voltage from PSU is allowed to keep the diagnostic led blinking.
This state can be triggered by any kind of fault, the blinking led in this case is not an error code.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or DVD connected.
If that does not work, and you keep having a led on (sometimes flashing) in front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The led light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the standby fault mode.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Dec 09, 2009
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I get a red screen and then it goes black no picture i get sound just no pic the red led light blinks 7 times
In most cases on these models the red crt is shorted and causes the set to go into a shutdown mode and flash the timer light 7 times. The part number for the red crt is 8-733-664-25 but is no longer available.
Nov 11, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Tv red light blinks off and on. Unplugged for an hour Tv worked for 10 monutes and then picture went to top left corner and got blurry. TV HAS BLINKING RED LIGHT AGAIN.
Replace Both of your convergence ICs one is bad ,but replace both STKs big black ICs also CK two resistors in same circuit 2.7ohms
Aug 11, 2009 | Samsung HCM4215W 42" Rear Projection...
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
Apr 10, 2009 | Samsung HCM4215W 42" Rear Projection...
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Black screen and red timer light is on
It may be the problem of the Dish connection or stablizer. Remove the stablizer and connect the Tv direct to switch board and re connect the dish connection. Then switch on the TV it will work.
Nov 04, 2008 | Samsung HCM4215W 42" Rear Projection...
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
