Question about Brother Office Equipment & Supplies
When the phone rings I get to it as quickly as possible, I lift the handset press the Tel/R button but there is no caller that I can hear. I have set the MFC to 8 but am still having difficulty and have to dial either 1471 or 1571 to get back to the caller, . Can you asist please
I cut out the fax which I do not use or require.
Posted on Oct 09, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Dec 22, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Cannot answer phone when it rings
when you lift the handset from the cradle try pressing the line number button on the handset or answer button on the handset.
May 29, 2009 | Vtech Cordless 6041 Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
I need my phone to ring at my desk
Turn the program toggle switch on (right side of KSU), go to the phone to be programmed and press the # button, then press the line button to ring, then pick up and then hang up handset. You should hear a confirmation tone. This will affect all line buttons, even the ones not pressed. Any line buttons not pressed will not ring. Do this at each phone.
Dec 30, 2008 | Inter-Tel Intertel 6123300 GLX Executive...
Caller id
try pressing the transfer button when the phone is ringing (without lifting the handset) - it should work through a cycle of displays until the phone number is displayed.
Nov 18, 2008 | Lands Phones
Call Waiting
When 2-nd call is ringing (you can hear ringing in the hand set while talking) word "Recall" appears in display. Press the button below the word "Recall" (top left side, dark grey button) and then press number "2". You will get connected with second caller while the first is put on hold. When finished with second caller, press again word "Recall" and then number "1" and you get connected back to first caller.
May 14, 2008 | Panasonic KX-TGA560 Cordless Expansion...
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
