I was going to purchase a Jazz Dv142 5MO Digital Camcorder, does anyone know if they are a good...
(More)
I was going to purchase a Jazz Dv142 5MO Digital Camcorder, does anyone know if they are a good camera?
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution...
(More)
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution or megapixel
When you stop recording, you can't start recording again or even turn the device off without...
(More)
When you stop recording, you can't start recording again or even turn the device off without removing the battery.
I recorded a video and now when i am trying to view it a message appears showing "Recording on...
(More)
I recorded a video and now when i am trying to view it a message appears showing "Recording on disc disabled". What can be done to view mthe recorded data
I have a Canon Elura 65 mini DV camcorder. When I open the tape cartridge cover, the carrier...
(More)
I have a Canon Elura 65 mini DV camcorder. When I open the tape cartridge cover, the carrier mechanism flips out in order to insert the tape. However, when the tap cartridge cover is pushed back against the carrier and the carrier moves to its correct position, instead of the carrier then lowering the tape into the camera to engage the tape spindles, it sounds a beep and ejects (flips) the tape back to where it was when first instered. No matter what I do, it will not lower the tape. However, with no tape in the carrier, the carrier lowers down and seems to do what is should. I have tried different tapes to no avail. This problem started immediatately after I accidentally dropped the camcorder.
