Question about Kenwood Juicers
How to clean filter of keenwood JE750 juicer
Hi when i want ot wash filter of keenwood JE750 juicer it is very tuff to remove filter from it's body.
Colud you please advice how to remove filter from it's body.
I am taking my juicer apart. I took the three screws out and the grinder plate. How do I get the filter out that is beneath the grinder plate.
Don't take the screws out! That plate is not meant to come off.
The filter unit is removed from the base by unscrewing it counterclockwise using the two holes in the plate that you unscrewed. The juicer originally came with a plastic tool with two prongs that fit in the holes and acted like a sort of handle you could use to unscrew the assembly.
If you don't have the tool, you can use two small screw drivers or jury-rig a tool out of a piece of coat hanger shaped into a U to gain leverage to dismount the entire filter/blade assembly for washing.
Hope this helps!
Mar 03, 2011 | Jack Lalanne Power Juicer 250 Watts
I need to clean my Jack Le Lanne CL003AP juicer after using it for the first time, but I cant remove the filter it seems to be stuck on and there are no screws to undo.
mcdevit75 here, There should be a rather thin Shiny silver bar that goes across the entire cover wher you put the fruit, vegatables in for juiceing, move that bar out of the way, either pull towards you or away while holding down the cover this is will allow the cover to lift off and expaose the filter for cleaning.
Jun 19, 2010 | Jack Lalanne Power Juicer 250 Watts
I have a kenmore 09001 800w juice extractor and would like cleaning instructions
Here is the owner's manual:
http://www.juiceman.com/uc/jm400uc.pdf
Feb 21, 2010 | Kenmore JEX328S Juicer
How do you take the filter and blade off to clean? it came together easily, but having trouble taking it apart...
It should unscrew in the opposite direction that the blade turns. Check the blade direction by momentarily spinning the motor with it's own power (don't touch it!). Once you know which direction it goes, unplug it and turn the blade in the opposite direction to remove.
Aug 19, 2009 | Jack Lalanne Power Juicer 250 Watts
How do I remove the filer cone for cleaning?
I suggest pick it up by spout & other side of bowl & shake a little & it should release from the base unit
Jan 06, 2009 | Breville Juicers
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Replace Body/Hub Combo
After reading your initial post and responding...yes, take a 1/4" socket wrench and loosen the four bolts at the other end of the motor. The hub will come off easily. If you have ot replace the oil seal, I have not figured out how to do that yet. I beleive the replacement hub has a new oil seal already installed. hope this helps
May 16, 2008 | Champion 2000+ Household Juice Extractor
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
127 people viewed this question
Top Kenwood Juicers Experts
David Payne
David Payne
eyecam
Mark Schmit
Mark Schmit
Are you a Kenwood Juicer Expert? Answer questions, earn points and help others
