Question about Ovens
Blanco oven not heating
The rear element in our blanco oven is not heating,could it be as simple as a fuse or is the element burnt out?
Simple is simple as, replace the element!
Posted on Oct 09, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I don't think it has any fuses, let alone for each element.
Most likely the element is burned out or there is some discontinuity (broken wire or bad connection) in the supply of power to the element.
You can remove the element and test it for continuity (resistance check using a multimeter). If it is open circuit, then it is definitely the element and needs replacing.
Posted on Oct 23, 2014
I have a blanco oven E815T1 BOSE166W2, always seem to have trouble with it. Although I have had it about 6 years, used it only about 20 times. Replaced the clock last time, now the heating light will not...
The simplest answer is usually the right one n this case.
Check the fuses!!!
I am willing to bet money (and in a way I am, because you won't pay for a solution that is wrong) that it is simply one of the fuses.
Be sure to replace the fuse with the same voltage / amperage rating and type (for example, don't replace a slo-blow with a regular fuse)
Jul 27, 2011 | Ovens
I have a Elba Excelence cooker Px906. the lower heating element doesn't work. And the oven doesn't have enough heat. Is the element burnt out? If the answer is yes how can I replace it?
4 elements, 2 top , 1 back, 1 bottom. remove covers in oven to see rear and bottom if they heat.
possibly selector switch fault.
mine looks wired wrong from factory, cant for life of me see how it can heat as display indicates ???????????????????
Oct 19, 2010 | Ovens
Oven heating element will not heat up
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | Ovens
White powdery stuff inside the oven, now no heat
It sounds like the oven element has blown.
The powdery stuff you refer to is the insulation of the element that has blown out.
You will have to fit a new element.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
The main oven is not working, no fan or heat could this be a fuse? Stopped spontaneously, top oven and grill are working perfectly, only 2 years old. thank you
This sound like the heat element for the main oven is burnt out, replace the main heating element and this should correct the problem.
Nov 14, 2009 | Ovens
Neff 1721 0ven element not working??
did you replace both fuses, if its a 240 volt element check the other fuse on the other leg of input power/120 volts + 120 volts = 240 volts
Oct 05, 2009 | Neff U1721 Double circotherm Electric Oven
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Ovens Logo
1,357 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
