Question about VisionTek TV Wonder 650 PCI Express Tuner Card
Audio does not work on tuner. VisionTek TV Wonder HD 650. I tried reinstalling internally and externally,update drivers,and still no audio on my PC? I try other speakers and even earplugs all do not work. Being that I belive it is the audio plug on the tuner is defected. 6 months old.
  • 121 Answers
M ake sure the jacks at the back is set correctly, from the tuner car auido out to the line in on the motherboard sound then make sur the aux cable is inside the case also fro the card to the motherboard mail me if any other questions, bertus_kriel@yahoo.com
Posted on Oct 08, 2009
Why can I not change the setting from pcm to dolby digital on my tv
You don't. You change the signal at the source device end, not the TV.
If you have connected a Blu-ray player or a games console, then set the device audio option to Bitstream. This will send a data stream to the TV that it will decode either as Dolby or DTS depending on the source signal format.
Dolby Digital is only an option for an external AV source connected via HDMI. That's the only way to get a Bitstream signal in to the TV. The TV's internal tuner is only capable of PCM audio. It's a DVB-T tuner (standard definition) rather than the DVB-T2 tuner needed for HD. Even then, only the HD channels are encoded in DD.
Iff your BD player or console is decoding to stereo PCM, then it's doing the same job as the TV. There's a small advantage with one of the audio processing modes in how it limits the dynamic range, but other than that PCM and DD will sound identical. This is especially the case with any TV that has no optical audio out, as in this case. The TV can't pass a DD signal out to an external audio system. So all sound is played via the internal speakers or headphone jack. It'll all sound the same, PCM or DD.
Oct 13, 2014 | Samsung Televison & Video
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
I want odyssey 501tv tuner internal driver software
i suggest u try the external TV tuner box...as those do not require any driver...not any installation of software...also it does not require ur computer to work...just ur monitor to be ON...
just connect ur monitor and computer thur the external TV tuner box and connect the TV cable to the tuner box...
Dec 23, 2009 | Computers & Internet
Tuner hardware not found,worked a while back , just now trying to record something and now this error comes up(ViZS pure tv-U48A3) I have surfed all over looking for an answer but no one including HP seems...
home premium comes with a set of default drivers romve the default audio driver and install you original audio drivers which are made for vista by your lp company
Oct 14, 2009 | Microsoft Windows Vista Ultimate Edition
The line in is not working.. 2 audio connectors one internal and one external came with d tv tuner card. i did not find any port on board(DG31PR) to connect the internal connector.so i connected the...
YOUR MOTHERBOARD IS NOT FULLY UPDATED WITH TV AUDIBLE DRIVERS. GO TO YOUR NEAREST OUTLET ASK FOR A RECENT MOTHERBOARD CD MATCHING YOUR MOTHERBOARD SO THAT YOU COULD INSTALL THE NECESSARY MODULE.
HOWEVER, WAIT FOR MY TOMORROW'S ANSWERS IN ORDER TO GIVE YOU A BRIGDE OF MOTHERBOARD TO EASE THE AUDIO OUT.
THANKS
WONDER
Aug 11, 2009 | Computers & Internet
External speakers for toshiba laptop problem
Check device manager and make sure the audio drivers are not disabled. If so enabled it. I am quite sure you have checked to see if its muted. If it is enabled and its not working, try updating the drivers or uninstalling and reinstalling latest driver audio driver OEM site.
**If you reinstall the same driver you might get the same error but its what a shot.**
May 22, 2009 | Toshiba Satellite A75-S211 Notebook
PAL VHS format
I'm not sure I understand your problem. What are you using that is PAL? If your VHS tapes are in PAL then the TV Wonder card, which can only handle NTSC format, will not produce a picture and you will not be able to transfer your movies. If they are in NTSC (U.S. or ***) then you should be able to transfer them just fine if you are using a computer from the same region. If you are using a computer from a different region (e.g. EUR) then this card is not your best solution.
Feb 21, 2009 | Diamond Multimedia TV Wonder HD 650 PCI TV...
Philips SAA7130 internal TV tuner card sound problem
hi,
try on a different slot on the pc or if you have another pc try using the tv tuner on another pc
if it still doesn't work your tv tuner card is bad.
further queries are welcome
Feb 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
"No TV Tuner Device"
Sometimes laptop graphic cards don't support video overlay, a feature needed to display TV on the windows graphic environment.
I guess you're using the USB version and not the PCI card you selected here at fix ya.
Jan 09, 2009 | ATI TV Wonder HD 600 PCI PC TV Tuner...
Media Center can't find digital TV channels for TV Wonder HD 600
Just to make sure, you do have analog tuners setup right?  Media Center 2005 requires analog tuners be working before digital tuners are allowed.
Oct 11, 2008 | ATI TV Wonder HD 600 PCI PC TV Tuner...
VisionTek TV Wonder 650 PCI Express Tuner Card Logo
401 people viewed this question
Top VisionTek Computers & Internet Experts
rafnix
rafnix
Computer Links
Robert Karst
Robert Karst
Are you a VisionTek Computer and Internet Expert? Answer questions, earn points and help others
