Question about Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
I JUST NEED THE INSTRUCTIONS ON HOW TO PROGRAMME A B&Q TE106 TIME
I JUST NEED THE INSTRUCTIONS ON HOW TO PROGRAMME THE TE 106 TIMER AS THE INSTRUCTION MANUAL HAS BEEN LOST
I solved this problem myself by Googling B&Q TE103 timer and downloading the B&Q instruction manual for the TE103 which I have printed and also saved to my computer so this does not happen again.
Posted on Oct 09, 2009
Testimonial: "I am just the greatest as I managed to solve my problem myself without the help from anyone else"
  • JWG161 Dec 11, 2010
    I have a B
Where can I find a Wiring diagram for hayward super II PUMP AND BOOSTER PUMP to new t106 intermatic and existing t104 for the booster?
Not sure if you will find such a diagram...
New installation?
Do the pumps have their own breaker?
Is your Super II pump a 2 speed?
What is the Thermostat for? Do you have a heater that you are trying to connect, so that the pump will come on when there is a demand for heat? Not really sure what the T-stat is mentioned for here?
You still only need to have 2 timers if I'm not missing something?
The T-106 will be for the Super II pump (presuming it is a 2 speed version) It will turn hi speed, on & off. or switch between them rather. I think I see why you may be inferring about a 3rd timer? You don't want to have pump running on "Low" speed continually. If so, Then you will need a 3rd timer (T-104) to provide power as Line to the T-106. The other T-104 will be for the booster pump for your cleaner.
The power for the Super II pump from the breaker will go to the 1st T-104 as "Line". Then from the Load portion of that timer, you will wire into the Line portion of the T-106. Following the instructions from the diagram at this website address for a PDF document:
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T106R%20Instructions.ashx
you will complete the wiring to the Super II pump via the "Load" side of the T-106
The 2nd T-104 (pool sweep pump) will be wired: from the breaker to the "Line" portion of the timer. From the Load portion of the timer, you wire to the booster pump.
Good Luck
Apr 29, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
Programmable Digital Timer Model TE106
Copy following link for possible TE106 timer manual:
http://waterheatertimer.org/pdf/Possible-manual-for-TE-106-timer.pdf
Add comment after trying instructions so we can get exact steps correct if necessary
Gene
Aug 11, 2013 | Hardware & Accessories
Error 106
Error 106 occurs when installing the programme
This might be down to a conflict with another programme, shut down all other applications when installing.
It can also be caused by a dirty or damaged CD installation disc, some files may not decompress correctly
You might find it is also caused by insufficient free disc space
Finally, make sure you have the latest net framework installed
http://www.microsoft.com/download/en/details.aspx?DisplayLang=en&id=19
This version was compatible with Photoshop 7, but you might find you need a later version
Jul 19, 2011 | Adobe Photoshop 7.0 for PC
Instructions how to programme noma model N1507 timer
I posted N1507 manual yesterday but have not heard yet if this is correct manual
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment and say if these instructions match your timer.
Dec 06, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I have a programmable timer model te106 (make unknown) with no instructions. any ideas how to get instuctions?
If its an intermatic timer then this link should take you right to your instructions http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
Nov 12, 2010 | Hardware & Accessories
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Oct 31, 2008 | Hardware & Accessories
Intermatic T104M 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
2,994 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
