Question about Canon PowerShot A75 Digital Camera
No image display on the LCD in record mode - Canon PowerShot A75 Digital Camera
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Oct 08, 2009
3 Suggested Answers
  • 99 Answers
SOURCE: LCD does not display image in record mode
ssue: The LCD/Electronic Viewfinder will not display an image or the image is distorted.
1. Press display (DISP.) button to turn the display on 2. If all troubleshooting has failed, please have your PowerShot A520 serviced
Posted on Feb 08, 2008
t00nz
  • 4738 Answers
SOURCE: in shooting mode lcd displays no image. Happened
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Nov 29, 2009
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
How do you turn off the flash on samsung sl202
When the menu is displayed on the LCD monitor, pressing the LEFT button makes the cursor shift to the left tab. When the menu is not displayed on the LCD monitor, the LEFT button operates as the FLASH ( ) button.  Selecting the flash mode 1. Select a desired Recording mode, except the [Movie] mode and the [DIS] mode. 2. Press the Flash button until the desired flash mode is displayed on the LCD monitor 4268flashicon.jpg The flash does not fire. Select this mode when capturing images in a place or situation where flash photography is prohibited. When you capture an image in poorly lit conditions, the camera shake warning indicator ( ã ) will appear on the LCD monitor.
Oct 24, 2009 | Samsung SL202 Digital Camera
No lcd display
Is there no display in all modes? If so then it might be a defective LCD screen. Is there backlight on the LCD? If there is no display only in record mode then you might have a defective CCD which is the image sensor.
Jun 23, 2009 | JVC GR-SXM260U Camcorder
No image
well perhaps you forgot to switch it to the playback mode (red switch on the power ) in the record mode you have to choose between lcd and viewfinder . further more it is possible to switch the display off .
the camera needs enough power i reccommend 2500 NIMH
accu's
Apr 18, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Canon PowerShot A75 Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
