Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
I have an old larger version of the Digital Synchrony and have a message that says 'hot water ventilate'. I have tried to run hot water through the machine using the hot water tap/button but nothing happens. It eventually tells me to turn the tap off. The machine heats up and makes a noise but I can't get any water flow at all. Any ideas?
    President:
  • 1,618 Answers
Check the end of the steam spout that may be blocked, use a paperclip to clear. If you still get the same result then the machine needs to be descaled.
Posted on Oct 08, 2009
  • Lumi Reed Nov 13, 2010
    I have the same problem on a Syncrony Digital Compact and it happend right after I descaled it. I used the descaler bought from partsguru.com and this is what I've always used. First, descaling took less than a minute, as well as the rinsing process, after which I had the "ventilate" message. Ventilating, it took about 1 hour to empty the tank. I took the brew unit out, cleaned behind it, cleaned the spout etc. Put everything back on and now no water is coming out at all when I ventilate and after a few seconds it stops and dispays "Hot water, Turn Knob". I turn the knob and goes back to ventilate. I think there is no water going through the system. The part with the spring in the tank works properly. Please HELP! I have been taking good care of my 3 yr old Gaggia just to avoid situations like this.
Why in my saeco VENTILATE message comes? Also grinder is working continuously why?
On grinder it might be set too fine...
On ventilate, there is an air lock in the hydraulic system, run the hot water cycle for a few seconds to clear.
Jan 12, 2011 | Starbucks Saeco Italia Digital Barista...
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
What does ventilate mean?
"Ventilate" simply means that there is an air pocket caught in the system and running water through it can fix the problem. When the ventilate message appears, you will need to run hot water through your steam/hot water wand as if you were going to fill your cup with hot water. If the message does not go away after doing so, you will have to run hot water through your wand continuously into an empty container (emptying one full water reservoir if not more). Once your display screen reads "Select Product, ready for use," you will be ready to brew delicious coffee again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | Gaggia Syncrony Compact Digital Espresso...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Constant ventilate message
mine says the same thing, run hot water from the hot water/steam nozzle until the message disappears. do this a few times, mine is working fine after doing that. hope this helps
May 09, 2009 | Saeco Royal Professional Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
New Royal espresso machine
It means you have an airlock in the water system. It can occur when you refill the water tank also.
Quite often you can run the hot water nossle untill the airlock clears. You will hear it splatter and then it should be sweet to go.
Jan 25, 2008 | Saeco Royal Professional Espresso Machine
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
212 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
