Question about Fujitsu Siemens Computers & Internet
Different lines of color appearing at the top of screen
Different lines of color appearing at the top and bottom of laptop screen
    Scholar:
  • 67 Answers
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor (in the same time) that means the video card is ok and the problem could be: the screen of the laptop or the invertor or the cable that attaches the screen to the motherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Posted on Oct 09, 2009
Testimonial: "thanks for the help... i will go repair my laptop."
Horizontal vertical lines on Laptop screen
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 04, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
Colored lines appearing from bottom to top of the screen.
the LCD is a very complicating device for all CP. you may check it by disassemble it to it's LCD and connect the ribbon wire/flex of the LCD firmly... but this problem is best to replace it with a new LCD... very complicated device indeed
Jun 03, 2010 | Sony Ericsson w580i Cellular Phone
Vertical lines on screen
Hold one side of the screen need top and flex slightly (Not twist, FLEX) if the full screen appears and lines are gone, you may need to have this fixed by a shop or replaced totally.
May 02, 2010 | E-Machines M6810 Notebook
THERE IS A VERY FINE VERTICAL LINE FROM TOP TO BOTTOM OF MY SCREEN. THIS CAME ON A FEW DAYS AGO AND DID NOT INVOLVE ANY NEW PROGRAMS. THE LINE HAPPENS TO BE PURPLE IN COLOR AND STARTS ABOUT 1/5 OF THE LEFT...
Its a hardware problem with your monitor, and it most likely won't go away. If its a laptop and its really bothering you, you can have the LCD panel replaced for $500 or more.
Sep 18, 2009 | Apple iMac G4 Desktop
Vertical color lines on the display
this is due to fault in the screen take it to the technician
Sep 02, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
Acer Aspire 9810 Screen Problem
Hi No otto,
On the bottom row of keys, you will see one marked Fn, in a different color. Hodl that and look at your top row of keys. Should be one with a laptop screen, and a monitor. The little graphics will be the same color as the Fn key. Tap that once, wait, see if the screen comes to life. Usually that key is set to choose "Just laptop screen, just external monitor, or both", with each tap.
Good luck,
Jan 06, 2008 | Dell Inspiron 6000 Notebook
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Computers & Internet Logo
308 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
