Hi! Got a bang olufsen mx 3000 tv that just gone dead. the red light comes on then i turn it on but that's about it. Do you think its the tube that's gone?
    Sergeant:
  • 244 Answers
Could be the projector bulb is dead. open it up and check the bulb. if it's discolored and burnt looking, you need to replace it. if it's still under warranty, the bulb may be covered- but i doubt it. if the bulb looks good try removing it and re-placing and try again. it may be a little loose, because of thermal expansion and contraction when it cools down. a wee bit of wd-40 can help! i mean, put some on a paper towel, and apply to the threads, or bayonet connector, whichever! if its 'spring loaded', a little wd-40 on the base contact couldn't hurt either! be careful with the wd-40- it's a great contact cleaner, but is flammable!!
so use very little and let it evaporate a little- the bulbs get very hot!
good luck! by the way, the bulbs are not cheap!
Posted on Oct 08, 2009
Testimonial: "great help! "
  • 122 Answers
Mx 3000 is old crt tv based on old thomson icc chassis and not worth fixing.
Posted on Dec 14, 2009
Bang olufsen tv
Check its back-light comes ON or not. Contact any service technician.
Oct 27, 2013 | Televison & Video
Bang & olufsen Beovision 7- Unable to turn television on When trying to turn the television on using the remote. WAIT appears on the top right side of television.
Nice TV set. Try first unplugging the tv for ten minutes, this quick hard reset will drain power from tv, and sometimes it solves the problem when TV is freezing on startup.
If this soes not work there must be a service reset procedure.
Aug 17, 2008 | Televison & Video
Not reading discs
Hello
The laser beam comes out of the laser pickup unit is weak. Replace the laser pickup unit with same type and number.
Jan 05, 2012 | Bang and Olufsen Audio Players & Recorders
Beovision MX 7000. Crackling noise emanating from speakers followed by picture jump. This happened on a couple of occasions then one final crackle, slight burning smell, no picture - power light pulsing...
Check 2 areas,capacitors c102 c103 c104 for burnt joints all in deflection cct.and burnt connector at scan coil at tube end,if its this second problem c102 and line output transistor may also be faulty.
Mar 12, 2010 | Bang and Olufsen Beotalk 1200 Digital...
Bang & Olufsen Beosound 3000 Ouveture CD Problem....Please Help!
Chances are you will need a replacement cd mech assy to fix this problem assuming you have already cleaned the laser lens(cotton bud with ethyl alcohol or isopropanol).dont know of universal remote for b&o but some specialist remote replacement companies do one for beolink1000 which will operate your product.
Feb 15, 2010 | Bang and Olufsen Beosound 4000 Shelf...
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
Picture tube
Ur tv tube it still good.It ur deflection board have burn capacitors and transttors.The Fly back transformer is dead also,that where the noise came from.
Dec 07, 2009 | JVC HD-61Z575 61" Rear Projection...
Cannot get colour picture
check tv colour system is correct for your region, this is shown in the tuning menu, adjust if required
May 16, 2009 | Bang and Olufsen Beosound 4000 Shelf...
The wire on my Bang and Olufsen has come off
this job can be done from the front but it is very fiddly so suggest youprevent hair loss by taking to b&o repairer.
Feb 06, 2009 | Bang and Olufsen Beosound 2000 Shelf...
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
