Question about Xerox WorkCentre M-24 Color Copier
System unavailable in xerox pro 255 :(
Hi to all,i'm having a problem with xerox workcenter pro 255, it doesn't start, the only thing it displays when i switch it on is
System unavailable. Do not power down until the power down message appears and then
Communication error Try powering down then on again
Please call for assistance if problem persists
Please someone can help me :(
  • 1 more comment
  • borad_14 Oct 09, 2009
    Thnx for the answer :)
    Actually that's what i did, a tech is coming to fix it, and i will post the solution here if someone else will have the same problem.
    Thnx again!
  • bulldogchief
    bulldogchief May 11, 2010
    The only thing you can really do is call Xerox and have a tech come look at it. There is no way I could fix that problem without being right there working on it.
  • Robtmai
    Robtmai Nov 27, 2013
    The software module battery has died. Replace and boom its back. Lets hope you cloned a backup first
  • 21 Answers
Esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Posted on Dec 02, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Could be your power supply
Posted on Nov 30, 2009
    Problem Solver:
  • 15 Answers
CHECK THE DEVELOPER HOUSING ASSEMBLY
Posted on Nov 16, 2009
My workcenter Pro 416 is fading out on the left side of paper and I already changed the toner what do I do next
You have to check two things: the image on your drum and the transfer unit checkwhether they are cornas, strips or rolls
Apr 27, 2012 | Xerox Office Equipment & Supplies
I have Workcenter PRO 416 and display says change toner but after replacing toner,the same message comes up.
I had that happen before. It turns out the refilled toner cartridge I was using was the problem. When I bought the cartridge I thought I was getting a new one. They were refills. You may want to try another cartridge if you have one.
Good Luck
Nov 30, 2010 | Xerox WorkCentre Pro 416 All-In-One Laser...
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Aug 07, 2009 | Xerox Office Equipment & Supplies
I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
May 02, 2009 | Xerox Office Equipment & Supplies
I need a vistapatch for Xerox workcenter pro 412
Sorry M8!
There arent any patches for making that model working with Vista, not on Xerox site; http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WorkCentre_Pro_412&Xlang=en_US&Xcntry=USA#Firmware%20&%20Machine%20Upgrades
And nowere else on the net
Good luck
Nic
Mar 20, 2009 | Office Equipment & Supplies
Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Sep 21, 2008 | Xerox WorkCentre M118 Black and White...
Secure Printing
What brand and model number copier is this?
Jun 09, 2008 | Office Equipment & Supplies
Xerox WorkCentre M-24 Color Copier Logo
1,571 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
