Question about Breadman TR875 Bread Maker
I can not get bread pan out i lift handle straight up and firmly wont budge from bottom?
  • leighntonyr Oct 08, 2009
    this is brand new never used
  • 120 Answers
Sometimes the paddles are surrounded by the baked bread and it will require a very firm pull to release it. That should do it.
Posted on Oct 08, 2009
I cannot get my bread pan out of the bread maker, no matter how I try to lift it! The instructions say to tilt it to the left and then pull- which did not work then I followed the suggestion of lifting it...
Most bread machines are held in by 2 little spring clips...one on each side.
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the stern "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Sep 11, 2011 | Cuisinart CBK-200 Bread Maker
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
Bread pan stuck-brand new machine Model CBK200WS
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the little "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Apr 18, 2011 | Cuisinart CBK-200 Bread Maker
The bread pan is stuck in machine at the bottom. How can it be removed?
Feb 23, 2011 | Cuisinart CBK-200 Bread Maker
I can't figure out how to take the bread pan out. The instructions state to remove it and wash prior to use. There are no instructions on how to remove it.
Your pan is held in by two spring clips, one on each side of the pan. They are under tension in order to hold the pan steady while the mixing occurs. Lift the lid all they way open and grab the metal handle on the bread pan with both hands. "pop" the pan by lifting straight up with a little ****. That will cause the clips to lose their grip and your machine will kind of "pop" out. When you are ready to bake bread you may have to "pop" it back into place. Remember that.
In fact go ahead and practice popping your pan in and out so you get confident with how the little spring clips work.....so you will be ready next time you are ready to bake bread in it....Best wishes!
Jan 08, 2011 | Cuisinart CBK-200 Bread Maker
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
I have a new bread maker . When I unpacked it, the bread pail is secured in the machine. Normally, I lift the handle of the pail, twist it and out comes the pail. This is my first Cusisnart, and the...
Hi, those function as little spring clips to hold your pan in. There is no twisting of the pan with your new machine. Just pull straight up with a little "pop" (use both hands and just pop up on the handle) and your pan will pop out. When you bake your first loaf just push the pan straight down until the pan clicks back into place under the little clips and you are ready to bake!
Oct 20, 2010 | Cuisinart CBK-200 Bread Maker
New Bread Maker, pan will not come out
The metal clips in my bread machine are just to hold it steady. You should pull the pan straight up.
When I take the loaf out of the pan after it has baked, I take the pan out and then set it on its side and wiggle the the thing on the bottom that makes the paddle turn loosen the paddle. Then I tip the pan over and holding the pan by the bottom and the handle, I dump the loaf out onto a kitchen towel to allow the bread to cool. It is recommended to allow the bread to cool for a few minutes for easier removal, but if the bread stays in the pan too long, it makes the crust soggy.
Mar 16, 2010 | Oster 5838 ExpressBake Bread Maker
How do i remove the bread pan from the machine it is cuisinart bread maker
 Grasp pan handle with a potholder, press down on outrer housing,lift handle sharply releasing pan .Now who can tell me how to stop my CBK200 from burning each& every loaf?        Dave from Succasunna,N.J.
Dec 11, 2008 | Cuisinart CBK-200 Bread Maker
Can't remove the bread pan
The same thing happened to me yesterday. I made my first loaf and then I couldn't get the bread pan out. We kept pulling and yanking on the bread pan until it felt like it was going to break! This morning, my husband called Cuisinart. The man on the phone said he has the same machine at home, and that you just have to pull it really hard. He said don't worry, it won't break, just pull it. My husband pulled it again and it came out. I guess he just got the right angle on it.
It was definitely stuck from the bottom, not from the side clamp things. The man on the phone at Cuisinart said that after you use it more, it becomes easier to remove the bread pan. We put the bread pan in and then pulled it out a few times, and it seems like now it comes out easily, the way it should.
I felt obliged to respond here, because I was very discouraged after reading this thread last night. I was about to return the machine. I hope this solution helps.
By the way, my first loaf yesterday was the Rosemary Bread from the cookbook that comes with the machine. It was AMAZING.
Sep 10, 2008 | Cuisinart CBK-200 Bread Maker
Breadman TR875 Bread Maker Logo
99 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
