Question about LG 37LG60 37 in. HDTV LCD
I have a LG 32LT7 LCD TV which has developed two problems over the last few months : 1. Recordings frequently fail (sometimes with an error message about time settings) 2. After a bit of channel switching, the remote control ceases to function (apart from volume) and I have to keep rebooting the TV (sometimes manually). Is there a memory problem with this model ? I am getting fed up with it.
pilot210
  • 39 Answers
SOURCE: No picture on startup and random remote cntrl functions stop working
Common problem on this set is the main board p/n AGF33761101. However, you might try a 'quick fix' mod on this set which involves locating and bypassing components.
I do think that the replacement board just have these 4 coils bypassed on them already, so you might be able to save some $$$ if you're electronics-savvy by removing and discarding coils l4010, l4011, l4012 and l4203... then jump the solder pads they were on with small bits of wire, making very sure not to short to ground. Good luck!
Posted on May 19, 2009
  • 458 Answers
SOURCE: LG 37LT 75 faults Picture freezes everything
Call out an LG engineer, there are software updates which control the operations of the TV, it would appear that you have an older version & need this to be updated.
Posted on Jan 08, 2010
Testimonial: "Thanks for quick response and info. will try this."
omaharox
  • 165 Answers
SOURCE: "Function Not Available" error on LG 47LG50 LCD TV
A software upgrade may resolve the issue if not the main Pcb. would need replacement.
Contact LG during normal business hour 8-6 central time.
1 800 243-0000
They may help you out also let them know if you are having a lipsync issue.....Wink wink
Posted on Jan 20, 2010
  • 901 Answers
SOURCE: lg will not respond to remote.
Does it work without remote OK.
You have to go to service mode menu and adjust. Only service center can help you.
Posted on Apr 07, 2010
Testimonial: "thanx buddy.now it is spontaneously working again but I will call the service center today."
  • 102 Answers
SOURCE: hi my lg lcd model
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Posted on Feb 16, 2011
Tv turns off and sometimes comes back on then right back off
had a similar problem with my lg and it took 3 tv repair service visits with main control board being replaced on 1 visit that fixed for about 1 month then failed again, eventually the last engineer replaced the capacitors on the main control board with more robust capacitors and that solved it . hope that helps
Mar 02, 2017 | Cars & Trucks
Delayed sound on lg LCD TV
My guess is that a chip or chips are beginning to fail. These chips can sometimes be replaced but be sure to get a written quote because sometimes it is more expensive to fix then it is worth. It is also not always a perfect fix. Unless chips are replaced with identical chips sound can be out of sync, tv features can be lost or any other possibilities.
Nov 10, 2013 | LG Televison & Video
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
The lcd tv (lg 42LG5000) which is now about 15 months old has developed a fault which is intermittent some times when first switched on sometimes after half an hour an hour the left side of the screen...
The backlight inverter is dropping out, on the older lgs the backlight inverter is separate from the power supply, if this is the case you can only obtain it with a new panel.
otherwise the newer lgs have the inverter built on the power supply.
in this case you can replace the entire power board.
May 20, 2010 | Televison & Video
Error messages temporarily blocking our programs
Reset your TV to default settings through the menu, go from there.
Feb 07, 2010 | Element Electronics FLX-2210 22 in. LCD...
LG 37LT 75 faults Picture freezes everything locks only solution is to pull plug and then restart. Occasionally just get black screen whaen changing channels. Recordings failing due to "time setting error"...
Jan 08, 2010 | LG Televison & Video
May 18, 2009 | LG 32LC7D Television
42LG50 HDMI error message
pull the plug on your tv and cable box for 1 minute and start fresh. glitches like this happen all the time with hdmi. if this does not cure, the error message you get needs to be posted.
Feb 27, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 37LG60 37 in. HDTV LCD Logo
403 people viewed this question
Computer Repairing
Computer Repairing
