Question about Nintendo GameCube Console
My game cube doesnt read any disks
When ever i try my disks in my gamecube it doesnt read them
  • dones Dec 30, 2007
    1.any game i put in , the console can't raed it
    2.i tried diff. ways to clean discs
    3.i put the console off and took out the wires
  • shutch Dec 31, 2007
    I having the same problem my gamecube is not reading the disk, and when i get it to read the disk it only does it for a little while.
    Problem Solver:
  • 16 Answers
Your lasers are shot. Get a new system.
Posted on Feb 05, 2008
My gamecube does not spin the discs that i put into it and does not read them. Is there something i can do to fix this without having to buy a new one?
One time I ccidently touched the lens in my 10 year old gamecube so now the lens and the laser dont read the discs anymore because it is knocked out of anglement so you could buy a new gamecube now or buy a wii because wii's can still play gamecube disc's too.
default.jpgGame Cube Disk Read Error Fix (Advanced Skill)
May 19, 2010 | Nintendo GameCube Console
Will leaving a game cube on pause for a while hurt it????
If you do it for an extended period of time, yes, it will hurt it.
Most newer video game systems, including the GameCube, use lasers to read the discs which hold the games on them. Whenever your system is on and the game is reading, the laser is working. Unfortunately, we are all learning that lasers have limited lifetimes. As a result, leaving your system on pause can cause wear and tear to the laser.
The gamecube has been the most reliable system of its generation. Big reason is that you cannot play DVD movies on it. When you use your Playstation or XBox as a DVD player, it prematurely burns out the laser.
Oct 05, 2009 | Nintendo GameCube Console
The game disk could not be read.
It sounds like the disc reader is dirty, it's the little clear circle right under where a disc would go, closest to the back of the unit.
To clean, open disc cover, locate the disc reader, use a dry soft towel or some toilet paper and gently wipe it off, sometimes even a little dust can cause a problem. This should do the trick. If it doesn't, then either the disc is scratched or the Game Cube has something wrong with it.
hope this helps!
Sep 20, 2009 | Nintendo GameCube Console
I bought a gamecube online and it wont spin the disk
Sounds like you need the Gamecube sensor switch replaced. That is a small door device for detecting when the Gamecube DVD door or lid is closed allowing disc initiation to begin. When your Gamecube doesn't detect disk at all and simply continues the message: "Please insert a NINTENDO GAMECUBE DISC," this is the problem. You can test this by inserting a game disc, opening the Gamecube door, and then closing it. If the message "Please insert a NINTENDO GAMECUBE DISC" remains unchanged, and there is no spinning of the disk, then your GameCube lid closed door sensor is probably broken and should be replaced. You can search Google for Part GCPT032, or for GameCube Lid Closed Door Sensor.
An easy fix if you know how to open the Cube. It's cable simply plugs in, and it is held by one tiny screw.
Sep 05, 2009 | Nintendo GameCube Console
I have 2 nintendo game cube and they out of 20
If each system will read different specific games, then its the systems. You can get them repaired, but they are honestly so cheap now that you would actually be losing money by not just replacing one (pretty sure it still works out alright for two, just not sure).
Aug 04, 2009 | Nintendo GameCube Console
My gamecube wont read my game disc
Its either the game disc or the lens of the gamecube. Try cleaning the disk or try another disc. If the cube still doesn't read the disk your lens is probably scratched in which case you would need a new gamecube.
Mar 07, 2009 | Nintendo Mario Kart: Double Dash for...
Games arent starting
Possibility #1:
The disk reader of the game cube is damaged
Possibility #2:
The disks are damaged
Dec 07, 2008 | Nintendo GameCube Console
Game cube not reading disk
I have a game cube that does the same thing. I open it while it's turned off and put my finger on the eye and slide it back and forth a few time. It works after a few tries. I think the gears that move the eye are wore out.
Sep 20, 2008 | Video Game Consoles & Games
Disc wont read and game won't spin
I Had The Same Problem! And I Have A Solution. Unscrew the top off and look inside.
there is the off and on switch on the opposite side to the right of it are 2 little switches, they have probably been displaced, they must be held back, the problem is they are running the disks around and it they aren't in the back they wont do anything.The Laser Should Be Cleaned using a Q-tip and Peroxide. Don't Use Too Much Just Clean Off The Laser, If That Doesn't Work, Its A Problem Inside The Machine, And is Extremely Hard To Fix, If Thats Your Problem, I Would Just Buy A New One For 99$ Rather Then Paying 80$ For Some Guy To Look At It And Say You Cant Fix It, If He Can Fix It, You Were Lucky, But If I Were You, I Wouldn't Take That Chance, Try What I Said, It Worked For Me, Now My Cube Is As Good As New. XD
I Really Hope This Has Helped You.
-XoX-Alyy-XoX-
Nov 03, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
