Question about OCE Office Equipment & Supplies
Where on an Oce tds600 do you go to refill the D5 developer?
You have to pull the developer unit to add dev
Posted on Apr 09, 2010
Oce tds600 error code in 05701
This is a "developer pollution" error. You probably are getting a message referring to a failure to optimize what you are trying to print.
That being the case, perhaps a change of the "ink" is in order or whatever you can do to clean the machine as something something is gumming up the developer..
This OCE is a Cannon company. If your manual has no cleaning instructions, you are at the mercy of techs familiar with doing the process for your machine. Or, you might get lucky with tech support of Cannon. Typically, manufacturers would be about the only ones able to identify what such codes means. Hope this helps.
Nov 09, 2014 | ErrorExpert Computers & Internet
TDS600 Error Code 08005
This has to do with one of the thermistors in the fuser section. I would recommend you call an authorized Oce/Canon service representative. The part is delicate and difficult to replace.
Apr 02, 2014 | OCE Office Equipment & Supplies
Tds600 error 22001
This is usually a bad CPU-I/O Board.
Sep 04, 2013 | OCE Office Equipment & Supplies
Have a tds600 that has just started printing everything with black lines or streaks of some sort down both sides of printed image. Any help??
Hi it could be an issue with the drum cleaning blade check to see if the drum is clean what you can do is do a few copies say 5 copies then check the drum to see if it is clean if it is not clean then replace the drum unit assemble or replace the drum blad
the other item to check is the fuser unit upper fuser roller is there any damage to the roller is the surface of the roller intact or are there several areas damaged if so replace roller
Feb 10, 2011 | OCE Office Equipment & Supplies
Oce 7056 error code 0501
something has gone wrong with the developer/toner section. Call for service, these are not user fixable.
Oct 01, 2010 | OCE Office Equipment & Supplies
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Jul 13, 2009 | OCE Office Equipment & Supplies
Put wrong toner in machine now prints are black
There is only one way to solve the problem. Call a oce service rep. to come out and have them vac. out all of the wrong toner out of the hopper & developer unit and give the bill to the person that put the wrong toner in to begin with.. Good Luck...
May 27, 2009 | OCE Office Equipment & Supplies
193 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
