Question about Dell 3100cn Laser Printer
How i can fix the error 016-302 restart printer???
    Scholar:
  • 138 Answers
This is a little bit of a tricky one, First, remove any LAN/USB cable and cancel any print jobs. You will have to remove the top cover to easily rotate the "rubber" belt until you see the silver square appear near the foam "window"...actually more like a cutout.
OR
Remove the drum cartridge from the top of the printer. Now, stand it up with the blue roller up and facing you. Then turn the blue roller on the very edges, so your fingers did not touch until a silver box shows up in the window (where the foam was) on the bottom right. Put it back together, and that should do it!! Good Luck :)
Hope This Helps
Posted on Oct 08, 2009
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 6 Answers
Posted on Jul 11, 2018
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Dell Support Phone Number 1-844-395-2200
to contact to Resolve your problem. Dell Technical Support Phone Number 1844 395 2200 Dell Help Repair
Posted on Feb 23, 2017
    New Friend:
  • 3 Answers
For Dell Printer Tech Support
contact on 1-800-935-0537
http://global-printer-support.net/
Posted on Jul 30, 2014
5 Suggested Answers
SOURCE:
komguy
  • 2306 Answers
SOURCE: 016-302 please turn off printer.
That error is a CPU error, you may have to un-plug the network or USB cable when you power cycle the printer, could just be a document it is unable to print, and needs to be cleared without cables. Otherwise the CPU could be damaged from a static shock or something like that...
Posted on Oct 09, 2009
SOURCE: Error 016-302 on Dell 3100cn
drum cartridge replace soon
Posted on Oct 30, 2008
  • 35 Answers
SOURCE: error 016-313
Try a firmware update.
if that doesn't solve it, reseat controller card.
if that doesn't solve it, replace controller card
For the 370 error, try the same steps. If they don't solve, then replace the Machine Control Unit.
Replaceing these parts can get expensive.
Posted on Jun 15, 2008
  • 73 Answers
SOURCE: error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
Posted on May 02, 2011
How do I Fix Samsung Printer Offline Error?
Best Solutions to Troubleshoot Samsung Printer Offline Error
Solution 1: Check Your Samsung Printer Connection
Solution 2: Check Printing Status
Solution 3: Restart the Printer Spooler Service
If you are not satisfied with the above answer or want this answer in details, then contact with canon printer repair service number 1-800-600-6962 to fix Samsung printer with an offline error.
Apr 03, 2018 | Samsung Office Equipment & Supplies
HOW DO I FIX ERROR 0X05
that an internet explorer problem try this (http://www.solvusoft.com/en/errors/runtime-errors/microsoft-corporation/internet-explorer/0x05-internet-explorer-8-error-code-0x05/
Oct 23, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Paul
Nov 25, 2013 | Lexmark X560n Laser Printer
Y CRUM Error Error 093-950 restart printer
If new, did you remove the safety paper?
Nov 25, 2013 | Office Equipment & Supplies
...UNABLE TO CLEAN error code 50'' my printer is
The hard drives are in a USB externa enclosure, set up as RAID 1 and are formatted as Mac OS Extended (Journaled). I do not save any TM back ups to them and they work after a restart and then sometime later start to provide the error message anytime I try to save to them. A restart usually fixes the issue for a finite period of time. Disk Utility runs and tells me the disks are fine. I never have trouble accessing data from them.
For more help visit cbrtechsolutions
Sep 03, 2013 | Brother DCP 165C Compact Color Inkjet...
59.62 error
hp color laser jet 9500 error 59.62 how fix
Jan 28, 2012 | HP LaserJet 9500mfp Printer
Error no 5200 occurred
remove your cartridge. clean the surface contact where the terminals inside the printer touches. Use a clothe moistened with alcohol. Return it back and restart the printer.
If errors remains, press and hold down Stop/Reset button and wait until printer self restart before releasing the button.
That should fix it.
Jan 24, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Error u162?
Press and Hold the STOP/RESET button and wait until it self restart.
Release the STOP/RESET button when the printer is restarting
Dec 13, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Dell 3100cn Laser Printer Logo
18,957 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
