Question about Kenmore 63942 Dryer
Kenmore dryer. 80 series. 6 years old.
Dryer runs but does not heat. had overtemp switch replaced. ops ok now. is there a reset botton on this switch? repair took only 10 minutes.
  • 3 more comments
  • tech helper Dec 24, 2007
    just wondering bacause of short time to fix.
  • Anonymous Jan 02, 2008
    dryer does not turn
  • Kenmore80 Feb 24, 2008
    Dryer Spins but dosen't get hot
  • Anonymous Sep 22, 2008
    The dryer runs but does not get hot. It's a Kenmore 80 series ( gas)model#110.74832400. Purchased 4/2005. Help!
  • MRitchie01 Oct 11, 2008
    Is there a reset button for the heating element on a Kenmore 80 series front load gas dryer
    Problem Solver:
  • 14 Answers
Heat relay switch
Posted on Dec 25, 2007
Kenmore series 80 gas dryer 6 yrs old will start and tumble but will not heat up
Gas dryers have an ignition panel that gets hot and when it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Kenmore Dryers
There is no heat in my Kenmore 80 series dryier. The drum is spinning and it seems that there is an air flow coming through, it's just could. The brakers are fine (there are two of them and they are...
The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Click on the link below for the details.
Troubleshooting an Electric Dryer Not Heating
Jan 19, 2011 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Trying to service Kenmore 80 Series Electric dryer. Dryer runs but does not produce heat. Have Fluke Meter. OHMS 9-11....
Follow the wiring diagram on the back access service panel or inside the control head.
I suspect the element is bad, but it could be the overtemp stat or thermostat.
Let me know if you have any further questions.
Jan 29, 2009 | Kenmore 62872 Electric Dryer
Dryer no heating up
defective thermal fuse ,,replace
Dec 13, 2008 | Kenmore 72802 Gas Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
There is no reset button on these thermofuses unfortunatly. Sometimes you can have a timer go out and cause a fault in the thermostats, thermofuses, etc. Doesnt happen to often, but it does happen. Be sure before you spend a lot of money, that you thoughly clean and check you dryer vent tubes or pipe. A clogged vent tube will normally cause major league problems (i.e. burned thermofuses, busted elements, out-of-temp thermostats, slow or no drying conditions, etc.). You can replace these yourself pretty easy if you have some hand tools (call Sears to fix and you can buy a new one) and a couple of minutes. Let me know if you want further instructions or help. Good Luck!!!! JIm
Dec 29, 2007 | Dryers
Kenmore 63942 Dryer Logo
367 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
