Question about Trident BLADE T64, (32 MB) PCI Graphic Card
Where would i find an oil journal on a ford 5.4 trident to install an valve to sample oil
    Genius:
  • 1,027 Answers
You can tee off on the Oil Pressure sensor, and add a needle valve to get your samples. Your local garage should be able to point it out for you.
Posted on Oct 09, 2009
How to switch off oil pressure light&get rid bearing knock
its possible that your bearing clearance is not right thats why you loosing oil pressure and have a knock
Sep 06, 2016 | 2008 Ford Bantam 1.3i
Oil light comes on at low rpm but oil level is right up
Do not ride the bike any further, otherwise you could have a big bill.
1. Check the electrics on the oil pressure switch and light 2. Buy a new oil pressure sensor, an easy fix 3. Oil pressure release valve malfunctioning (could have the wrong spring in it or worn piston clearance in valve body), an easy fix . 4. Leaking oil seal (or backwards installed) on the crankshaft (under the timing cover), an easy fix. 5.Worn out oil pump (when oil gets hot it loses it's viscosity,or it's thickness and thus an oil pump with worn clearances will not pump it effectively) also easy to fix. 6. Worn main bearings/worn crank journals (oil escaping from clearance between crankshaft journals and shell bearings on crankshaft big end resulting in loss of pressure). This could be the case on a bike that has high mileage Requires a rebuild. 7.Also, the drillings in the timing cover and oil pump through crankcase to oil pipe junction block must be clean.
Oct 20, 2014 | 2007 Triumph Speedmaster
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
The engine has blown. I need to replace it or change pistons and rings. How difficult is it to change pistons and rings?
It can be time consuming and the end result may not be desirable if you haven't done it before.
--- The following is just a sample of what to do once the engine is torn down: Pistons and Connecting Rods
  1. Before installing the piston/connecting rod assembly, oil the pistons, piston rings and the cylinder walls with light engine oil. Install connecting rod bolt protectors or rubber hose onto the connecting rod bolts/studs. Also perform the following:
    1. Select the proper ring set for the size cylinder bore.
    2. Position the ring in the bore in which it is going to be used.
    3. Push the ring down into the bore area where normal ring wear is not encountered.
    4. Use the head of the piston to position the ring in the bore so that the ring is square with the cylinder wall. Use caution to avoid damage to the ring or cylinder bore.
    5. Measure the gap between the ends of the ring with a feeler gauge. Ring gap in a worn cylinder is normally greater than specification. If the ring gap is greater than the specified limits, try an oversize ring set. Fig. 5: Checking the piston ring-to-ring groove side clearance using the ring and a feeler gauge tccs3923.gif
    6. Check the ring side clearance of the compression rings with a feeler gauge inserted between the ring and its lower land according to specification. The gauge should slide freely around the entire ring circumference without binding. Any wear that occurs will form a step at the inner portion of the lower land. If the lower lands have high steps, the piston should be replaced. Fig. 6: The notch on the side of the bearing cap matches the tang on the bearing insert tccs3917.gif
  2. Unless new pistons are installed, be sure to install the pistons in the cylinders from which they were removed. The numbers on the connecting rod and bearing cap must be on the same side when installed in the cylinder bore. If a connecting rod is ever transposed from one engine or cylinder to another, new bearings should be fitted and the connecting rod should be numbered to correspond with the new cylinder number. The notch on the piston head goes toward the front of the engine.
  3. Install all of the rod bearing inserts into the rods and caps. Fig. 7: Most rings are marked to show which side of the ring should face up when installed to the piston tccs3222.gif
  4. Install the rings to the pistons. Install the oil control ring first, then the second compression ring and finally the top compression ring. Use a piston ring expander tool to aid in installation and to help reduce the chance of breakage. Fig. 8: Install the piston and rod assembly into the block using a ring compressor and the handle of a hammer tccs3914.gif
  5. Make sure the ring gaps are properly spaced around the circumference of the piston. Fit a piston ring compressor around the piston and slide the piston and connecting rod assembly down into the cylinder bore, pushing it in with the wooden hammer handle. Push the piston down until it is only slightly below the top of the cylinder bore. Guide the connecting rod onto the crankshaft bearing journal carefully, to avoid damaging the crankshaft.
  6. Check the bearing clearance of all the rod bearings, fitting them to the crankshaft bearing journals. Follow the procedure in the crankshaft installation above.
  7. After the bearings have been fitted, apply a light coating of assembly oil to the journals and bearings.
  8. Turn the crankshaft until the appropriate bearing journal is at the bottom of its stroke, then push the piston assembly all the way down until the connecting rod bearing seats on the crankshaft journal. Be careful not to allow the bearing cap screws to strike the crankshaft bearing journals and damage them.
  9. After the piston and connecting rod assemblies have been installed, check the connecting rod side clearance on each crankshaft journal.
  10. Prime and install the oil pump and the oil pump intake tube.
  11. Install the auxiliary/balance shaft(s)/assembly(ies).
OHV Engines CAMSHAFT, LIFTERS AND TIMING ASSEMBLY
  1. Install the camshaft.
  2. Install the lifters/followers into their bores.
  3. Install the timing gears/chain assembly.
CYLINDER HEAD(S)
  1. Install the cylinder head(s) using new gaskets.
  2. Assemble the rest of the valve train (pushrods and rocker arms and/or shafts).
OHC Engines CYLINDER HEAD(S)
  2. Install the timing sprockets/gears and the belt/chain assemblies.
Engine Covers and Components Install the timing cover(s) and oil pan. Refer to your notes and drawings made prior to disassembly and install all of the components that were removed. Install the engine into the vehicle. Engine Start-up and Break-in STARTING THE ENGINE Now that the engine is installed and every wire and hose is properly connected, go back and double check that all coolant and vacuum hoses are connected. Check that your oil drain plug is installed and properly tightened. If not already done, install a new oil filter onto the engine. Fill the crankcase with the proper amount and grade of engine oil. Fill the cooling system with a 50/50 mixture of coolant/water.
  1. Connect the vehicle battery.
  2. Start the engine. Keep your eye on your oil pressure indicator; if it does not indicate oil pressure within 10 seconds of starting, turn the vehicle OFF. WARNING
    Damage to the engine can result if it is allowed to run with no oil pressure. Check the engine oil level to make sure that it is full. Check for any leaks and if found, repair the leaks before continuing. If there is still no indication of oil pressure, you may need to prime the system.
  3. Confirm that there are no fluid leaks (oil or other).
  4. Allow the engine to reach normal operating temperature (the upper radiator hose will be hot to the touch).
  5. At this point any necessary checks or adjustments can be performed, such as ignition timing.
  6. Install any remaining components or body panels which were removed. prev.gif next.gif
Oct 17, 2010 | 1995 Ford Thunderbird
Replacing crankshaft pulley/balancer assy procedure. 1994 Merc Topaz 2.3 4cyl.
Crankshaft and Main Bearings REMOVAL & INSTALLATION NOTE: When draining coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. CAUTION
The EPA warns that prolonged contact with used engine oil may cause a number of skin disorders, including cancer! You should make every effort to minimize your exposure to used engine oil. Protective gloves should be worn when changing the oil. Wash your and and any other exposed skin areas as soon as possible after exposure to used engine oil. Soap and water, or waterless hand cleaner should be used. 2.3L Engine
  1. Disconnect the negative battery cable.
  2. Drain the cooling system and engine crankcase.
  3. Remove the engine from the vehicle.
  4. Remove the crankshaft front pulley, front cover, timing chain and sprockets, cylinder head, oil pan, oil pump and intermediate driveshaft.
  5. Remove the rear oil seal cover bolts and remove the cover.
  6. Remove the piston assemblies. NOTE: Mark the connecting rods and bearing caps so they can be installed in the proper cylinders.
  7. Remove the main bearing caps and bearing.
  8. Carefully lift the crankshaft out of the crankcase, so No. 3 thrust bearing surfaces are not damaged.
  9. Remove the main bearing inserts from the engine block and bearing caps. NOTE: For cleaning purposes, the oil gallery and coolant drain plugs can be removed. To install:
  10. Wash the cylinder block thoroughly to remove all foreign material and dry before assembling other components. Check to ensure all oil holes are fully open and clean. Check to ensure the bearing inserts and bearing bores are clean. Clean the mating surfaces of the crankcase and each main bearing cap.
  11. Install the main bearings in the cylinder block. Note that the center front bearing is a thrust bearing and the front upper bearing has a small "V'' notch on the parting line face.
  12. Lubricate the bearings with clean engine oil.
  13. Carefully lower the crankshaft into place. Be careful not to damage the bearing surfaces.
  14. Check the clearance of each main bearing as outlined in this section.
  15. After the bearing has been fitted, apply a light coat of engine oil to the journal and bearings. Install the bearing cap in their original locations . (refer to numbers on caps). The caps must be installed with the arrows pointing to ward the front of the engine. Oil the bolts and tighten to specifications. Repeat the procedure for the remaining bearings. NOTE: Turn the crankshaft to check for turning torque. The turning torque should not exceed 4.5 ft. lbs. (6 Nm).
  16. Install the pistons and connecting rod caps. Check clearance of each bearing, as out lined in this section.
  17. After the connecting rod bearings have been fitted, apply a light coat of engine oil to the journal and bearings.
  18. Turn the crankshaft throw to the bottom of its stroke. Pull the piston all the way down until the rod bearing seats on the crankshaft journal. NOTE: Guide the rod to prevent crankshaft journal and oil cooling jet damage.
  19. Install the connecting rod cap. Align the marks on the rods with the marks on the cap, and tighten the nut.
  20. After the piston and connecting rod assemblies have been installed, check the side clearance between the connecting rods on each connecting rod crankshaft journal.
  21. Install the rear crankshaft seal and cover. Tighten the bolts to 5–7 ft. lbs. (7–10 Nm).
  22. Installation of the remaining components is in the reverse order of removal.
Jul 26, 2010 | 1994 Mercury Topaz
Low oil pressure
Just guessing, but it sounds like you are loosing pressure from the bearings.....If you had the crankshaft journals cut, or if they were slightly out of round to begin with, this can happen. Cutting removes material...the journals on most modern engines are too thin to do this (same weight saving idea that gave us rotors that you need to throw away) After cutting, they go egg shaped. Not cutting and starting with out of round condition will essentially give you the same problem but may take a bit longer to fail.
Of course, check all clearances and sealing points, but I believe that's where you will find the problem.
May 15, 2009 | 1998 Toyota Camry
Changing Camshaft seal
1. Install the camshaft after lubricating the journal of the camshaft with engine oil. 2. Install the camshaft bearing caps.a0b9a5d.jpg
3. Install the ignition coil. 4. Install the rocker arm and rocker arm shaft. Refer to "Rocker Arms and Rocker Arm Shafts" section. 83e48db.jpg 5. Using special tools, Camshaft Oil Seal Installer (09221-21000), press fit the camshaft oil seal. Be sure to apply engine oil to the external surface of the oil seal. Insert the oil seal along the camshaft front end and install by driving the installer with a hammer until the oil seal is pulley seated. bda0592.jpg 6. Install the camshaft sprocket and tighten the bolts to the specified torque. 2cbbe98.jpg
May 05, 2009 | 1996 Hyundai Accent
Fuel in oil, rover 3.9 v8
if your rocker shaft was busted and the valves were not opening, alot of the unburned fuel in those cylinders will end up in the crankcase. the problem is that fuel dries things out and hinders lubrication, the crankshft and camshaft bearing and journals can become damaged. fix your rocker, put fresh oil in, then change it a second time after about an hour of running, use a quality oil additive like MOA or Lucas stabilizer in the second change. low oil pressure can indicate worn crank and cam bearings and or journals.
Mar 08, 2009 | 1994 Land Rover Discovery
2000 escort zx2 part name and how to remove it
would like to help looked on one in yard thats in for repair and their isnt one,(europeon model ).where does the other end go too ?? white tape would have been better if its in the well just to the left of the no 1 spark plug their shouldnt be any oil their only a water jacket beneath it ?? strange one this,,,is their a sort of plastic button on the end peice like the fuel lines if so pull it out and it should come off.Honestly iam at a loss never seen this on a europeon model.
Dec 12, 2008 | 2000 Ford Escort
Trident video accelerator trident 96xx/938x problem
Here you go:
http://www.bioticaindia.com/trident-video-accelerator-96xx-938x-5-1-2001-0.html
Aug 23, 2008 | Computers & Internet
Trident BLADE T64, (32 MB) PCI Graphic Card Logo
70 people viewed this question
Top Trident Computers & Internet Experts
David
David
Juan Long
Juan Long
Level 1 Expert
NOEL
NOEL
Are you a Trident Computer and Internet Expert? Answer questions, earn points and help others
