Question about IBM Computers & Internet
Would not restart shutdown&startup after installing a new product
    Scholar:
  • 127 Answers
Your windows has encountered some registry errors and might have been interfered with. run system recovery and us e the disc that came out with your pc . if you do not have it anymore, use an xp or vista to replace the operating system but make sure that you do not go for formatting so that you will not loose your work.
send me a comment if you need actual prompt on this.
thank you
wonder
Posted on Oct 08, 2009
  • 252 Answers
What new product?
Try booting into Safe mode and uninstalling the application.
When you first start the machine continually tap the "F8" button. This will bring you to a screen where you will have several choices to start your machine. Choose "Safe mode" (using the cursor keys on the keyboard). You can try "Last known good configuration" but it doesn't always work.
After choosing "Safe mode" it will then ask what operating system (just hit enter if you have only one).
Then a DOS like screen will come up (listing the drivers that will load). Wait several minutes (shouldn't take more then 2 minutes) and the machine will then go into safe mode. It may ask which profile to load, so just make sure to choose one with "admin rights".
You will then be in "safe mode". Don't be alarmed because everything will look strange (it only loads the basic drivers to start the machine).
Go to Control panel and uninstall your application.
Hope this helps.
How to reboot
See this image. Reboot is now called 'Restart'. You have to click the little arrow to see the options.
May 03, 2015 | Computers & Internet
Laptop shutdown while reformatting and now unable to bootup
If it shutdown while reformatting the hard drive, restart from a installer CD/DVD and reformat the hard drive before installing the operating system.
Apr 23, 2014 | Computers & Internet
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
My laptop samsung NP300E5A when i make wifi off and i shutdown when i startup i found wifi on i want keep it off i want keep wifi and blutouth as i make off or on when i restart my laptop
Click on Charms menu > Settings > Network Connections, then set the device to airplane mode. If this doesn't resolve the issue, you may want to also contact Samsung Support directly.
Apr 17, 2013 | Samsung Computers & Internet
Asus Eee notebook startup issues
Unplug the power supply and remove the main battery, press and hold power for 60 seconds to get rid of any residual voltage. Re-install the battery and connect power supply, if no change! take laptop back to the place of purchase since warranty will apply.
Mar 20, 2012 | ASUS Eee 4G Notebook
Sudden shutdown
If the battery is full and still shuts down suddenly then it could be a heatsinking problem on your Notebook. Also try unchecking the option "Automatically Restart" from StartUp & Recovery section in System Properties.
May 03, 2010 | HP Pavilion dv6000z Notebook
The prompt for shutdown comes up repeatedly
try starting up with the system/install disk, select language then at the top there is utilities, select disc utility and repair first then repair permissions. Then select startup disc and restart. If this fails then do an archive and install.
Oct 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
Acer Aspire 1640Z laptop PC *refuses to reboot/restart*
ya go back make sure all latest drivers are instale d before u do sp 3 yes under msconfig go in ther then under startup tab disable all u dont need all junk starting with comp easting ram also after go to servcies next tab to left at bottem says hide microsoft products cheak that then anything left over u can uncheak then hit apply then close reboot k
Oct 08, 2008 | Acer Aspire 1640Z Notebook
Computers & Internet Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
