Question about Compaq (243890-001) 250-Watt Power Supply
The Ic inside the power supply is not working
Can any one tell what is the IC using in the power supply.It is possible to replace the IC and also the replacememt would work fine.
  • 121 Answers
Bye a new one it will be much cheaper and time spare
Posted on Oct 08, 2009
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch. Everything else works. Can anyone tell me what it takes to fix this. (I am an electrical engineer...
Without a Sams Photofact or a service manual I would go directly to the Power IC which is the largest Integrated Circuit mounted to a large heat sink. If you see any fuses they are probably for the power supply since any fused circuit on the speaker output would be ineffective because the IC would be damaged before the fuse would blow, but you need to check them anyway. Since the short was at the speaker output your problem should be at the final stage of amplification, which is the Power Amp IC. Prior to the early 70's you would have transistors mounted to a heat sink which could be individually checked and replaced. Then manufactures started to use the Power Amp IC which are more costly but eliminate having to find matched pair transistors. All you can check on the Power Amp IC is if you have an input using an oscilloscope or signal tracer and the power to the IC. If you have an input signal and power to the device with no output, I would replace the IC. Unless you have a test circuit for the IC you cannot test it completely unless you have a device like a Huntron Tracker or build a test circuit using a signal generator and a power supply to measure the gain of the IC with an oscilloscope. Short of ordering a service manual this is a good place to start.
Aug 15, 2011 | Audio Players & Recorders
My tcl tv model tcl 2009 has no power but led is blinking. I replace already the control ic TDA16846 but still not working. what is the possible problem regarding the power supply
A nice little Control IC but when they fail ithey take out a lot of components around the power supply especially the output FET rather catastrophically for the power board.
I would look elsewhere for your fault because if there is a flashing light, the microprocessor has power and that comes from the power supply.
Look for open circuit fuseable links.
Hope that helps.
Dec 10, 2010 | Televison & Video
I have a mitsubishi vs-4541/4542 tv with sound and no picture. What are my options?
I have not repaired this particular model. If this TV is a projection set,you have one of two possible problems. First....You may have convergence IC that has lost a ground contact to the signal board. We are discussing the board that has all your RCA connections and RF connectors. You may have to replace, possibly a STK-XXX series convergence IC. One or two capacitors near this IC, usually a bad cap will end the life of an IC and resistors. And replace a couple of resistors, these are standing tall next to the convergence IC. The next problem could be on the power supply. The power supply will almost always have the flyback transformer on it. If you can locate the vertical IC..This IC may need resoldering. You will see rings around the pins of the vertical IC. Replace the three or four capacitors next to the IC. A bad capacitor will overheat an IC and cause solder grounds to separate. Thanks for asking and show a few hands of support!
Dec 09, 2010 | Mitsubishi Televison & Video
I'm not getting any audio whatsoever - whether it be the TV's own speakers or my headphones. Suggestions? Thanks.
Possible failure of the output IC in the Tv's audio section.
First of all open and check for possible failure of the main power supply to the output IC, Check if the series fuse/fusible resistor has opened, if after replacing the same issues come up then it is confirmed that the IC is defective.
If power comes to IC then check on the bias resistors around the IC or the feedback loop,-- capacitors in this section.
Aug 28, 2010 | Sharp LC19SB27UT LCD TV
Im having conpaq presario power supply with part no. 243890-001.It is not working.I consulted one technician stated that IC is not working.Can u please answer which IC this power supply is using and if the...
You don't sound like you are very skilled in micro-miniature repair so for you it is cheaper in the long run to just replace the power supply. You can order it from HP.com. Some computer stores have old power supplies for sale. You may get lucky.
Oct 08, 2009 | Office Equipment & Supplies
Goodmans model gtvl32w26hdf. Switched itself off. have changed fuse, with not difference. blue standby light comes on, using remote press standby blue light goes off, screen remains black.
Good Day SIr, sound to me like your switching power supply is not working properly, there is an IC that controls the switching action of your power supply, this MAY be the reason why it stays off. locate the IC at the power supply section, replace it then test. There is also a possibility of open low value resistors near the switching transistor (very hard to locate). hope this helps.
Sep 23, 2009 | Televison & Video
Sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Jan 21, 2009 | Sony Televison & Video
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Also had a power surge,...
The GE (actually RCA) 46GW945 uses the PTK195 chassis. There is a separate power supply for the convergence circuits in those sets. The earlier versions used a switching transistor but most sets use the STK730-010 power IC. I have seen many of those IC's stop working after a power surge, resulting in very curved sides with screwy colors. You can remove the back and you will see the 2 main boards at the bottom of the set. The convergence power supply board is mounted above the board on the right (when viewed from the back) and has a pretty large black IC mounted on a little heat sink, labeled STK730-010. Replace that IC and the colors should return to normal. If you do not have experience replacing IC's and working on TV's then allow a qualified tech to handle it for you.
Jul 13, 2007 | GE 46GW945 46" Rear Projection Television
Compaq (243890-001) 250-Watt Power Supply Logo
141 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
