Hallo. My name is Svend and I come from Denmark. Nickname: sc_galleri Password f8c5a I have a Agfa Sherpa 24M (epson stylus pro 7600), which I have some problems with. I have Reinstall a new mainboard (epson stylus pro 7600 mainboard) in the printer and now the printer says Flasch merory sum error 002009. In the manuel, I can see, that I have to reinstall Epson firmware. I have`nt bin able to find Epson firmware on the internet, so I talk with Epson.dk and they told me to install Epson Printer Service Utility. I have done so and open the program Printer: Epson Stylus pro 7600-Dye Function: Firmware Update Wenn I pull the next botton, I get the answer that the printer is not ready. I have turn on the printer and the usb cable is ok. What can I do now?
EPSON STYLUS PRO 7600 Leaking ink One of my
sir the printer head of your printer is already thin... try to change the printer head...
Oct 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
I have an Epson Stylus Pro 7600 with a Agfa Sherpa 24M sticker on it. Baught some cartridges from Epson but I get Wrong ink message. Any way to work around this problem?
You need to either buy AGFA cartridges ot apparently you can take the chip off the AGFA cartridge and put it on a Epson or compatible. It will always say it's empty but should still work
Jun 18, 2010 | Epson Stylus Pro 7600 InkJet Printer
Ink for Agfa Sherpa 24m
Hi, did you find a solution to this question as I have the same problem, can't find the Agfa cartridges anywhere.
James
Mar 20, 2010 | Epson Office Equipment & Supplies
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
80 people viewed this question
k24674
jasbo
jasbo
