Hi Ihave a windows media player problem. It is set as defualt but when i when i click on any movie file it will play sound but the media player will not open if i click the media player button in the launch bar it opens and is playing, if I right click and click play in wmp it opens and plays. also if I close the media player with out stopping the video media player shuts down but the sound keeps playing. this has only just started to happen in the last week. I am using vista. cheers.
  • bundydan Oct 09, 2009
    thanx all good now.
    President:
  • 1,188 Answers
The problem seems to be seem to be some corrupt registry entries. It can be corrected easily, however, by a re-install.
Below is a link to download Windows Media Player 11. Download it and install it. Make sure you have closed every program and internet explorer also before installation.
Windows Media Player 11 (25 MB)
If you have already the installer file, you can install from it also.
This should solve your problem. In case your problem is unsolved, reply back. In your reply, please include what flavor of Vista are you using (Basic, Ultimate etc) and what service packs have you applied.
Posted on Oct 08, 2009
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Ihave downloaded AVI movie files onto my iomega screenplay MX but they wont play,can you help?
Hi, Convert that's movie files compatible in your iomega screenplay MX files like mp4 etc. To download free any video converter software for PC click the following link http://www.filehippo.com/download_any_video_converter/ then install > double click> next>finish. icon already in the desktop. Also download this http://www.filehippo.com/download_vlc/ VLC media player for PC's is a highly portable multimedia player for various audio and video formats as well as DVDs, VCDs, and various streaming protocols without external codec or program.
Jun 28, 2011 | Computers & Internet
Hi i have a western digital home edition 2 tb hard drive that now when i play an avi movie file i get sound and no picture or picture and no sound also these files play fine on windows media player so now...
> these files play fine on Windows Media Player
Then, continue to use Windows Media Player.
Or, tell us what alternative program that you use that gives "sound-and-no-picture" or "picture-and-no-sound".
What version of that program?
Windows XP? Vista? 7?
Any more "possibly-relevant" details ?
Feb 01, 2011 | Computers & Internet
How to play straight from hard drive.
Hi And Welcome to Fixya,
You can used Windows Media player, By opening the file. Open your Windows Media Player click on file>open>then browse for folder of Video_TS folder double click it then you find a bunch of stuff inside that folder. Click any one of the file then on your keyboard hit CTRL+A to highlight all, then click open.
All file will go and open to your Windows media player. Try to played it. About nero you can open a largest file and then played it there.
Jan 18, 2010 | Pinnacle Dazzle DVD Recorder
HI, I've movies on my computer and they don't play
u need to install the codecs for the window media player.....if u donot have den download those from this web site
http://www.soft32.com/download_2592.html
other just download vlc media player...its a very good software n it plays almost all the file extensions....good luck
Sep 03, 2009 | Computers & Internet
WMP error message-C00D11B1
Can you try this:
  • Start-> Control Panel->Hardware and Sound
  • Sound / Manage Audio Devices
  • Highlight your audio device
  • Properties
  • Advanced
  • In the Exclusive Media section, UNCHECK the box "Allow applications to take exclusive control of this device."
  • Apply
Hope this helps.
Thanks.
Mar 08, 2009 | Microsoft Windows Vista Ultimate Edition
How do you put movies dvds and videos on your mix max mp3 player?
Ok these are the directions from start to finish.
You need Prism Video Converter and Windows Media Encoder 9 series. You can google both and download for free. You use Prism Video Converter to convert AVI or whatever file to WMV and then use Windows Media Encoder 9 Series to convert the WMV file to a WMV9 file. I know its stupid but if you follow my directions it will work and it cheaper then buying the individual cartridges. Once you have these installed do the following.
Click and open up Prism Video Convertor.
Click to "ADD FILES" on top toolbar. Find and choose the movie you want to convert and double click on the movie and it will add it to the list. Add all the movies that you want to convert. Each one takes about an hour.
At the bottom choose a different output folder. Then scroll through the OUTPUT FORMAT tab at the bottom and choose. .WMV
Click on ENCODER OPTIONS and change everything to the following:
Video Compressor------ Windows Media Video 9
Video bit rate ------------- 4096
Sound Compressor ----- Windows Media Audio 9.2
Sound Format ------------ 128 kbps,48 kHz Stereo CBR
Press ok and then click on VIDEO OUTPUT OPTIONS and change everything to the following
Make sure that there is a check next to RESIZE VIDEO "Shrink or enlarge video to selected size."
Width---- 220
Height --- 176
Make sure that there is a check next to CHANGE FRAMERATE
30.00
Click on OK and then CONVERT when the movie is finished you can move on to the next step
STEP 2
Open Windows Media Encoder 9
click on COVERT A FILE and press OK
Then choose your source file ( the movie you just converted with Prism)
Then Choose a new output file like make a new folder and name it MIX MAX MOVIES and click ok
On the next screen just press ok. Don't worry about the setting at this point because we will change them later.
Name the movie. and click ok and FINISH
Once the converter starts press the STOP button on the top toolbar., its RED, a window will pop up, click CLOSE to close the window. Then at the top of the converter click on the PROPERTIES tab. A window will pop open. Click on the COMPRESSION tab in the middle of several tabs. Click EDIT on the right hand side of the COMPRESSION window.
Now you should see 2 tabs. A GENERAL tab and a 259kbps tab
On the GENERAL TAB change everything to the following:
Make sure Video and Audio are both checked
Audio CBR Windows Media Audio 9.2
Video CBR Windows Media Video 9
Click the 259kbps tab and change to the following. ( If you see something I don't mention here THEN DON'T CHANGE IT )
Audio Format 128 kbps, 48 (NOT 44) kHz Stereo CBR
Video Size 220X176
Frame Rate 30
Key Frame Interval 2 sec
Video Bit Rate 384K (this is a little tricky. MAKE SURE IT SAYS 384K)
Buffer Size 5 sec
Video Smoothness 0
Decoder Complexity Simple
for a total of 521.02
CLICK APPLY and wait a few seconds for it to apply and then START ENCODING on top toolbar. When this movie is finished it will play on your MIX MAX, if it still says that the FILE IS NOT SUPPORTED then you have to go into the setting on the max and change the mass storage setting. There are 2 choices can't remember off hand what they are but choose the opposite one obviously and try again. Also you actually have to go to the movies or video tab on the max player not NOW PLAYING cuz that button is pointless.
any problems email me @ cera1756@gmail.com
I have converted many movies that have worked on both our players so if you follow these directions correctly there shouldn't be a problem.
ENJOY
Jan 18, 2008 | Disney Mix Max Digital Media Player
Windows media players doesnt recognize music files
Use Media Player on your computer to SYNC you music files to your phone. After files a synced, go to Media Player on phone and click right soft key MENU and select UPDATE Music/Audio Files, then select SEARCH.
Dec 05, 2006 | Audiovox SMT5600
Playing the V3 movie files on media player?
The problem seems to be in the Media Player (or Windows) itself. I have V3 too and have no problems with playing the shot movies. The movies are in a standard AVI format which is usually recognized my Media Player. You may need to re-install all you codecs or even Windows ;-(
Sep 12, 2005 | Samsung Digimax V3 Digital Camera
Computers & Internet Logo
David Payne
David Payne
