Question about Accton CheetaHub Classic 2040 Networking Hub
What is the ip address to accton chtah hub router
  • 22 Answers
Click on START-RUN and write cmd (and ok)
This will open a command line window
There, write ipconfig and take notes of :
DHCP enabled (yes? no?) If YES:
Gateway and DHCP Server must be your router's IP address.
Posted on Oct 22, 2009
    Guru:
  • 81 Answers
It will be 192.168.2.1 ... or you can try default IP for other routers ... 192.168.1.1 / 192.168.0.1.
Regards,
Shrey
Posted on Oct 10, 2009
How To Find Your Huawei HG8245 Router IP Address? Please tell me the detail steps. Thank you!
1 Either find your router IP address using this guide: How To Find Your Routers IP Address.
2 Or you can use our Free Software to find your router IP address. PF Static IP Address and PF Router Detector are both free software applications that will help you find your router IP address.c:\docume~1\admini~1\locals~1\temp\%w@gj$acof(tydyecokvdyb.pnghttp://www.huanetwork.com/huawei-hg8245-gpon-terminal-price_p3630.html competitive price for HG8245
Jan 15, 2014 | Huawei Computers & Internet
I have a 8 port ethernet switch DES-1108 how do i connect it to a DSL cable modem and the 3 computers i have . do i need to use the router still. or what
If the computers only need to communicate with each other then you do not need a router.
Each of the computers must have the same Network name (workgroup) and have the same IP address range. If you have a fixed IP address on each of the computers the IP address range should be the same - for example 192.168.3.xxx (xxx being a number unique to each of the computers, BUT the first 3 group of numbers (IP address range) MUST be the same on all the computers.
If the computers need Internet access then a router is required and if there is insufficient LAN ports on the router then you need to add a network hub connect the router to tht hub and connect the computers to this hub. You would need to configure the computers to obtail an IP address automatically, the router will issue IP address to the computers automatically.
I would not recommend using the Ethernet switch with the router as it would require a more complex configuration.
May 13, 2011 | D-Link DES-1108 8-Port Ethernet Switch...
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Dec 29, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
How to check IP address if you do not know the old IP segment of the accton?
click start, run and type cmd, it should come up in command line and type ipconfig and press enter, it shows ur ip address
Aug 12, 2010 | Accton EtherDuo-PS (EN2024-6) Network...
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
I want to use my linksys nr041 as an extended network hub how do I do this
set it up as a static IP also set the gateway to the ip of the other router. example:
Router #1: IP address: 192.168.0.1
Router #2 IP address Static 192.168.0.2 / Gateway:192.168.0.1
Oct 25, 2009 | Linksys (NR041) Router
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
No have Drivers Accton CheetHub Classic 2040 Win XP
If this is a hub no driver is required, connect your CAT5 cable to it and the other end to your Network interface card and it is done.
Visit http://www.accton.com/ for more informtion.
Jul 03, 2009 | Accton CheetaHub Classic 2040 Networking...
Got an accton eh 2024 etherhub and wanna network 2 computers
Forget Windows XP networking wizard.Go to control panel>network connections>right-click on LAN connection>properties>select TCP/IP>click properties IP: 192.168.1.100Subnet: 255.255.255.0make the other PC's IP: 192.168.1.101To allow file sharing go to Control Panel>windows firewall>check file and printer sharing and click ok
Mar 27, 2009 | Accton EtherHub 24S (EH2024) Networking...
Accton CheetaHub Classic 2040 Networking Hub Logo
219 people viewed this question
Top Accton Computers & Internet Experts
David Payne
David Payne
Are you an Accton Computer and Internet Expert? Answer questions, earn points and help others
