Question about Hotpoint Ultima WF860 Front Load Washer
THE DRUM STOPPED SPINING HOTPOINT ULTIMA - Hotpoint Ultima WF860 Front Load Washer
    Genius:
  • Hotpoint Master
  • 1,474 Answers
Check motor brushes if over 4 years old....
Posted on Oct 08, 2009
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Our electric hotpoint dryer stopped spining & got hot & it smelled hot now we can't even get it to turn on
Let's start with the easy stuff.
Check the belt
Thermal fuses
door switch
Do you know where they are?
Dec 12, 2012 | Hotpoint Dryers
Drum has stopped spinning hotpoint wt960
looks like your bearings have gone if you can not move with hands looks like you need a new machine as to pay someone to fix this is a lot hope this helped
Oct 31, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WD860 machine has stopped mid cycle displaying f-04 I have taken the panel off the back and cleared out the tube from the drum by removinng the clip but this has not worked. On thurning the...
f04 is a pressure switc problem.
take the lid off and check the clear plastic hose is attached to the bottom of the pressure switch, a round part with wiresand the other end to the sumps breather tube.if it is and there are no holes or splits in the tube it may need replacing.
Feb 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
108 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
