Question about Grizzly Tools & Hardware - Others
Plastic and metal wheels are worn out need parts for grizzly combination sander model G1013, ser # 07060010
This sander is used in a machine shop. We can make the parts ourselves although I found the parts sheet and ordered the items from the company. Thanks for your help.
Posted on Oct 09, 2009
Palm sander not vibrating
Only real way to find out what is wrong is to open it up on this one. They are mostly plastic parts and you will probably find the broken part or where a gear is worn out.
Jul 04, 2016 | Ryobi Tools & Hardware - Others
Wont turn off
contacts in starter box are welded together or on off switch is shorted unplug it remove cover at on off switch look at switch if ok go to starter box with contacts in them youll see problem replace part as needed
Sep 20, 2013 | Grizzly G1071 Oscillating Spindle Sander
Need switch for milwaukee model no 6066 serial no 0075355593 sander/grinder.please help THANK YOU.
Part # 50
http://www.ereplacementparts.com/milwaukee-6066-ser-753a-sander-parts-c-131_4779_5141.html
Aug 12, 2013 | Milwaukee Tool Milwaukee 6066 - 6 7''/9''...
Parts manual sander model 315.11751
Confused:
"Problem with Riding Mowers & Garden Tractors"
"Parts manual sander model 315.1175"
"Need large plastic driven gear for dust impeller"
So is this a mower/tractor? ... If it's a manual sander, why does it have a gear, driven by plastic, for a dust impeller? Who is the manufacturer of said ambiguous item?
Have you contacted the manufacturer?
Sep 02, 2012 | Garden
Parts
I have the same sander, and cannot get parts anymore, so I carefully cut out a piece of sheet metal, and drilled holes, and put it on. so it might not say stanley, but who cares? I don't. and if it doesn't last as long, who cares. its more help than I got from stanley, who was bought out in 1973 from what I read.
Oct 18, 2009 | Stanley Hand Tools
Sander stops
There can be a few problems. First is your air supply the right pressure and volume for the sander. Check that at the quick connector to the sander itself. Second, if it is cold and moisture is high, ice can get into the sander which will slow it way down. Third, and probably most likely cause, is the sander well oiled and the parts inside clean. Fourth, mechanical issues: the drive motor may be well worn out inside, the bearing that the main shaft for the sander may be worn out & so forth. Hope this helps you, Rick
Apr 28, 2009 | Air Tools & Compressors
Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Apr 01, 2009 | Tools & Hardware - Others
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Tools & Hardware - Others Logo
172 people viewed this question
Top Grizzly Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Grizzly Tool and Hardware - Other Expert? Answer questions, earn points and help others
