Question about Emerson EWD2202 DVD Player/VCR
How to set up to copying a video tape. - Emerson EWD2202 DVD Player/VCR
    Problem Solver:
  • 15 Answers
This is a snap, as long as you have a second VCR if not you can't do it.
1. Hook the out put line(s) from VCR1 to the input line(s) on VCR2.
2. Put recorded tape into VCR1 and press play.
3. Set VCR2 to the channel that VCR1 is playing on, it's usually 3 or 4.
4. rewind the recorded tape and put the blank into VCR2.
5. Press record on VCR 2 and play on VCR1.
if you want an exact copy stop here. . . or
6. pause VCR2 when ever something comes up you don't want to record, ie a commercial if you'r re-recording a movie from TV. be for warned though each time you re-record an analog recording, like a VHS tape, the audio and vido tracks get further and further apart. After about the second or third time you re-record a tape you'll hear something before you see it, or vice-versa. I hope this helps you out.
Posted on Feb 01, 2008
When copying a vhs tape to dvd, and there is only a short amount of video on the vhs tape, how do I just burn that and not the whole 2 hour tape? When I stop the copying it does not finalize and do not...
You must be able to watch what is being reocorded.
After the part you want to record is finished stop it.
Also the recording can be set for a set amount of time.
Jan 07, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I video taped a wedding and am trying to copy from my camcorder "VHSC" to VHS RECORDER - PROBLEM IS I AM GETTING AUDIO BUT NO VIDEO when i try to replay from vhs tape on VCR
I can only believe that you did not connect everything (the yellow video cable) correctly.
Tape to tape copies are normal and typical. Please consider retrying - and just do a few minutes of test video to confirm that it is working.
If you were doing a digital translation, I could understand a problem - but VHS to VHS should be a straight copy.....
Let us know how the test works. (BTW, I had a bad quality video cable - and had to replace it with another - which worked (and everything would display on my TV but would not copy onto another tape. My expert said that a copy protection thing in the record mode of the VHS recorder was the issue - ONLY a strong signal will be copied.
Oct 14, 2009 | Quasar VM-L153 VHS-C Camcorder
Copying home made video from sony Hi8 tapes to Sony DV mini tapes
Sony DCR-HC21 has a multi-AV in, your Hi-8 should have a mini (4 band) to multi AV out. The cable would look like a stereo headphone cable on one end with thre RDA type plugs on the other end; red, white, yellow. The mulit in on the DV would probabaly be the same type connector. Youd have to use a coupler set for the two multi-av cables to bridge video to video and audio to audio. Come out of the Hi8 into the miniDV recorder. You should not need a Dazzle unless you want to transfer to a PC for editing before moving video back to a miniDV tape.
Jul 26, 2009 | Sony DSR-30 Mini DV VCR
Magnavox H2160MW9 VHS tape "recording not allowed" to hard drive
RIAA has prodded the electronics manufacturers into putting copy protection into their recorders. You are allowed one copy, I believe, and you will be able to make it to a DVD-R in VR mode. VR mode protects (how? dunno) the recording from being copied a second time. DVD-RAM and DVD-R (maybe -RW) in VR mode should allow you to make your copy.
RIAA - Recording Industry Association of America
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Copying 8mm tapes to dvd
try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Dec 27, 2007 | iLO DVDRH04 DVD Recorder
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Recording of video in order to burn to DVD on a GSA 5169D
put tape on the hole on top of the tapes and you shoud be able to record. its tape on the top or pull the top off i cant remimber which one it is but this is the answer.
Feb 21, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Emerson EWD2202 DVD Player/VCR Logo
91 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
