Question about IBM ThinkPad T43p Notebook
My computer crashes when the ATI software is loaded. When I uninstall the program the ATI grafics software the computer runs fine.
  • 408 Answers
The ATI software is not compatable.Check your graphics card type then go to the ATI website and get the right drivers/software.
Posted on Oct 10, 2009
I have issues with the second ATI FirePro V7800 card. I am running Window 7 pro - 64 bit. The motherboard is ASUS Sabertooth X58. Intel Corei7. Corsair 24 GB. Both two cards were working fine...
In order to further troubleshoot this issue, I would recommend the following:
Uninstall the ATI drivers from your computer.
Shut down the computer.
Remove the ATI card from your computer, and connect your monitor to the onboard video adapter.
Turn on the computer.
Ensure the ATI software was infact removed.
Reinstall the ATI video Card
Turn On the computer
Reinstall the ATI drivers ensuring to select the proper "CrossFire" configuration
May 21, 2011 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
APPCRASH error please help
When program files or files within your computer's registry have become corrupted, this can cause the programs to unexpectedly crash. When a program crashes, you will likely get an Appcrash error. The error message will say "Windows Media Player (or whichever program has crashed) has stopped working" and then list rows of technical information regarding the cause of the crash. Unless you are a computer programmer, you may never fully understand what caused your program crash, but that doesn't mean that you can't fix it.
Delete any new programs that you have downloaded. Often, the cause of corruption in a computer system are bad downloads that bring harmful files onto your computer. If you started to get the Appcrash error on your system after downloading a new program or software from the Internet, it's highly likely you have downloaded a bad product. Use the "Add/Remove Programs" feature in your "Control Panel" to get rid of the program immediately.
Uninstall the program that is crashing. It is possible to fix the program's corrupted files while the program is still installed, but to make sure that you clear the program files completely, it is safest to completely uninstall it from the system.
Run a full scan of your computer. Your computer should already have antivirus software installed that can scan for corrupted files and either fix them or delete them from your system. If you do not have antivirus software on your computer, that could be a big part of the problem. Purchase and install antivirus software as soon as possible. These are designed tor from outside threats. Once you have the antivirus program installed, open it and click "Scan Computer." The antivirus scan will isolate bad files and you will be given the option to remove them from your system.
  1. Reinstall the program that was crashing. Now that the corrupted files have all been removed, your program should run smoothly after reinstallation.
  2. Check for program incompatibility. If, after a thorough scan and cleaning of your computer and reinstallation of your program, the Appcrash errors continue, the program you are trying to use may not be compatible with your program. For instance, there are some DVD softwares, such as Media Now, that do not work correctly with Windows Vista. These lists can be easily found online. If this is the case, you will have to purchase a software program that is compatible with your OS
You should download a program such as RegCure and run it from time to time. If you are unable to download a copy let me know and I will give you a link on my web where you can download it.
Jan 16, 2010 | Microsoft Internet Explorer 7
Bad Display
The usual symptoms of the ati2dvag problem are:
  • PC crashes without warning, sometimes the display shows weird patterns before the crash.
  • Resolution may revert to the lowest resolution settings upon restarting your PC.
  • The CPU temperature may shoot up prior to crashing.
  • PC may not be able to reboot back after the crash, unless you turn off the power supply unit of your PC and switch it back on again.
  • Your PC tells you (sometimes only) that the ati2dvag driver has failed to function.
This is a universal problem afflicting thousands of PCs worldwide and can occur in totally new or old computers; it doesn’t discriminate. Imagine the frustration of buying a new PC only to have it crash on you after a few weeks and thereafter.
There have been many hypothesis’ postulated. Some say it is a very stealthy virus, some say it is an incompatibility with Windows XP SP2 and ATI, some say it is a problem with the hardware acceleration settings in the ATI graphic card, others say it is a problem within Windows XP itself…etc.
The 2 most common “solutions” are:
  • Reinstall the ATI driver. You are advised to launch Windows in Safe Mode (press F8 before Windows boots), go to Windows Add/Remove programs and uninstall everything ATI. Remove the DAO/MDAC component as well. You can use the ATI removal tool utility which can be downloaded from the ATI website. The complete set of instructions on removing ATI can be found on the ATI website.
  • Go to System Devices in My Computer > Properties > Hardware, and locate the option, PCI standard PCI-to-PCI bridge. This could under other names on your PC, so contact your PC vendor if you’re unsure. Right click, and select the “update driver” option. Manually search and install the PCI standard PCI-to-PCI bridge.
Jan 12, 2010 | Gateway CX200S Tablet PC
Iam from pakistan
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ATI that are available for your card.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
Jan 01, 2009 | ATI All-in-Wonder X800 XL, (256 MB) PCI...
New Vid Card, Comp Freezes when loading windows.
Fisrt you must Do a search online on how to make a deep uninstall of nvidia drivers.
Then...
Do "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove all ati or powercolor related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from the power color manufacturer that are available for your card.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Dec 27, 2008 | Power Color RADEON HD 2600 XT, Graphic...
Radeon X800 XL AGP Card Installation Error
You should do a deep uninstall of all of the ati drivers present in your system... here are the instructions.
The "deep uninstall" starts by first uninstalling all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ati.
Jul 08, 2008 | ATI Sapphire RADEON X800XL RADEON X800 XL...
Driver
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (you will need to do this at native vga mode).
You should have downloaded the most recent catalyst drivers from ati or the manufacturer of your pc.
Apr 19, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
I lost my cd that came with my radeon 9250 hardware
all u hav eto do buddie and u wann do is download latest version from www.ati.com ok under support 8.1 ect always update
Feb 03, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
IBM ThinkPad T43p Notebook Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
