Question about Car Audio & Video
Tec3m instructions I need to wire this 30a auto switching combi replay to charge my leisure battery and run my fridge when on the move. I really hope someone can help me.
Did you get a solution?
Posted on Nov 04, 2009
  • Jerry Weller
    Jerry Weller Nov 04, 2009
    Ha 6 little screws. The first two are for hooking up the 12 volt from your main car battery. you can use either one of them or both if you prefer.
    screw 6 and 2 are  for charging the extra batteries. If you have two hook one of the extra battery's positive to number 6 and the second extra battery's positive to number 2.
    If you only have one extra battery you can use either one of them or both for better heat dissipation.
    The screw 4 is a constant 12 volts power for hooking up anything you want outside of the charging circuit.
    the 0v is ground that you run a wire to from either the chassis or from the main battery's negative terminal.
    Hope this helped.
Do you only use the blue,green,and red wires on the grey socket or do still have to put the white and black to earth
Posted on Apr 11, 2011
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
Oct 09, 2016 | 2003 Ford Explorer
Need the wiring diagram for the aux circuit feeding caravan fridge power while the engine is running.
Understanding Caravan and Tow CarUnderstanding Caravan and Tow CarIn the beginning.... The first and oldest electrical system on caravans, that was installed way back when most caravan's were no more than small garden sheds on wheels were the rear lights that replicated the rear lights of the towing vehicle, usually no more than two side lights and two brake lights.
Illumination for inside the caravan was provided by gas lights fed from a small gas cylinder usually clamped to the "A" frame of the caravan. It wasn't long before the lighting system needed to be upgraded, as direction indicators became mandatory on cars, additional wiring was needed to replicate indicators on the rear of the caravan. Skip forward a few years and a rear fog light became mandatory, so a further upgrade was made to the lighting electrical system to allow the rear fog light to be installed. The wiring for these lights was connected through a 7 pin plug to the car that is commonly known as a "12N" connection.Sometime in between the indicators and rear fog light changes, people decided they wanted to replace the gas lights inside the caravan with 12 volt lights that could be run from the car battery. People often used old car spotlights or other 12 volt lights that were found in cars of the time as interior lights and these soon drained the car battery, so an "upgrade" was to install a second battery in the caravan that could be used to provide power for lighting. These were usually old car batteries. It would be another few years before the dedicated "leisure battery" came along. Originally, you would have to take this battery out of the caravan and charge it at home using a standard car battery charger. Again, in a continual developing process, someone came up with the idea of being able to charge the second battery in the caravan from the tow car while driving along the road, or when on site, being able to run the engine of the car and using a long lead be able to plug the caravan into the car to charge the battery for the next nights use of the lights, So a second "supplemental" electrical system was born and the "12S" (S for supplemental as to differentiate it from the 12N or Normal) connection came into being.he 12 Volt systems
The 12 volt systems are split into two. The first, and as we have seen, the oldest is the caravan road lights, that is to say the lights that are required by law to have on all trailers. These lights consist of "tail" or "rear" lights - rear side lights (red), brake lights (red), direction indicator lights (orange), reversing lights (white) and fog lights (red). Due to the size of a caravan front marker lights (white) are required and from 2013 side marker lights (orange) on longer caravans.
12N & 12S Vehicle Wiring
These lights are connected to the car via a 7 pin "12N" type plug or by a more modern "continental" style 13 pin plug. The road lights are usually a complete system with all the supply and earth connections being separate from any other electrical system on the caravan. One of the most common faults with road lights is problems associated with the earth lead, but more of that later.
The only road lights that are not connected via the 12N connection are the caravan's reversing lights. The original 7 pin socket when it was developed was thought to have enough connections for everything anyone could ever want. Unfortunately as the years progressed, the number of "spare" connection on this plug diminished, to the point where there was no spare connection for the reversing lights. However, with the advent of the 12S, this was taken care of.The second 12 volt system is the supplemental system. This is designed so that when towing, you can charge the caravan's leisure battery, power the fridge and in some cases power an electrical brake system. The design of the supplemental system has to take into account a number of things:-
• It must be able to charge the caravan's leisure battery only when the car battery is fully charged and the engine is running.
• It must be able to power the caravan's fridge - but not allow the fridge to flatten the car battery if the engine is not running.
• It must be able to power the internal 12 volt electrical system of the caravan, but turn everything off when the engine is running.
• It must not interfere with the correct operation of the road lights of the caravan or towing vehicle.
OK, so lets look at the first one -
"It must be able to charge the caravan's leisure battery only when the car battery is fully charged and the engine is running"roblems with this type of connection. If the car battery is flat and you try to start the car, a heavy current will be drawn from the caravan's leisure battery and would cause the caravan wiring to over heat and possibly cause a fire. It would also damage the plug and socket connecting the caravan's wiring to the car, as they are not designed to take the high currents involved in starting a car engine. So how can we do this safely?
Sep 29, 2016 | Cars & Trucks
Need some troubleshooting tips on a fireplace. I've got the pilot on but when I flip the wall switch nothing happens.
Most of these unit are controlled with a millivolt signal that is generated from the thermopile.
We see this often at the beginning of the year.
Remove the wires from you wall switch and clean them so you have new metal showing and tighten them back to the wall switch.
With your gas valve in the on position try the switch.
If this doe not work do the same thing to the wires on the gas valve where they hook to the TP/TH connecting and the Th connection.
More information can be found at www.allpartsinc.com
Nov 05, 2014 | Leisure HOMEPRIDE Electric Fireplace...
Battery dies on 03 yamaha after being ridden, battery wont hold charge..have replaced battery, stator, and regulator. wiring harness problem?
no not wiring harness! Unless the stator connector is unplugged.
check to make sure the charging fuse is not blown. Should be a 20A or 30A fuse.
When the bike is running test the battery to see if it is charging, should be between 13.25 volts and 14.5 volts.
Apr 04, 2014 | 1999 Yamaha TDM 850
Car battery charger that dont take all day to charge.
The higher the amperage the faster the charge, however a trickle charge always takes longer than a quick boost. In some cases a quick charge ends in a quick discharge.
Feb 26, 2014 | Electronics - Others
I need a fuse number and location or a fuse box diagram for the brake lights on a 2002 E350 super duty
go to the link bleow and follow it to the Ford web site, there you can download a free owners manual, all fuse box info u need is in the manual.
http://www.edmunds.com/ownership/howto/articles/120189/article.html
Sep 18, 2009 | 2002 Ford E350
Trailer towing fuses
Battery junction box (BJB) fuse(s):
  • 5 (30A) (trailer electric brake controller)
  • 34 (25A) (trailer tow turn relays)
  • 42 (30A) (trailer tow parking lamps)
  • 44 (30A) (trailer tow battery charge relay switch side)
  • 63 (15A) (trailer tow reversing lamps
Mar 20, 2009 | 2008 Ford F 250 Super Duty 4WD
Diagram of fuse panel under dashboard
2003 Excusion, V10, 2wd, Eddie Bauer
I had a hardtimefinding this informaton, hope it helps.
fuses
Fuse link
cartridge
2A Grey Grey — — —
3A Violet Violet — — —
4A Pink Pink — — —
5A Tan Tan — — —
7.5A Brown Brown — — —
10A Red Red — — —
15A Blue Blue — — —
20A Yellow Yellow Yellow Blue Blue
25A Natural Natural — — —
30A Green Green Green Pink Pink
40A — — Orange Green Green
50A — — Red Red Red
60A — — Blue — Yellow
70A — — Tan — Brown
80A — — Natural — Black
Passenger compartment fuse panel / power distribution box
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the panel cover to access the fuses.
Roadside Emergencies
To remove the fuse panel cover,
turn the panel fasteners
counterclockwise.
To remove a fuse use the fuse puller
tool provided on the fuse panel
cover.
The fuses are coded as follows.
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment Fuse Panel
Description
1 15A* Adjustable pedals
2 20A* Power point -floor console
3 20A* Power point – 3rd row
4 20A* Power point -instrument panel
20A* Power point -right rear quarter
6 20A* Trailer tow turn/stop relay
7 30A* High beam headlamps / Flash to pass
8 — Not used
9 20A* Heated mirrors
10A* A/C clutch
11 20A* Radio (main)
12 20A* Cigar lighter / OBD II
13 5A* Power mirrors/switches
14 15A* Daytime running lamps
10A* Driver’s seat module memory
16 15A* Rear seat controller
17 15A* Exterior lamps
18 20A* Turn lamps/Brake on-off switch (high)
19 10A* Body security module/4x4 module
— Not used
21 25A* Rear wiper motor
22 20A* Engine control
23 20A* Engine control
24 15A* Air suspension
10A* 4-Wheel Anti-Lock Brake System
(4WABS) module
26 10A* Airbags
27 15A* Ignition switch Run feed
28 10A* EATC module module/Front blower relay
coil
29 10A* Customer access
Fuse/Relay
Location
Fuse Amp
Rating
Description
30 15A* Highbeam headlamps
31 15A* Clutch interlock switch
32 5A* Radio (start)
33 15A* Front wiper
34 10A* Brake on-off switch
35 10A* Instrument cluster
36 10A* PCM Keep-Alive
37 15A* Horn
38 20A* Trailer tow park lamps and backup lamps
39 — Not used
40 20A* Fuel pump
41 10A* Instrument cluster
42 15A* Delayed accessory
43 10A* Fog lamps
44 10A* PATS module, transceiver
45 10A* Ignition switch Run/ Start feed
46 10A* Left-hand lowbeam
47 10A* Right-hand lowbeam
48 10A* Rear wiper motor
101 30A** Trailer tow electric brake
102 30A** Door locks/Body security module
103 50A** Ignition switch
104 40A** Heated backlite
105 30A** Injector driver module
106 30A** Front wiper main
107 40A** Front blower motor
108 40A** Auxiliary blower motor
109 30A** Heated seats
110 50A** Ignition switch
111 30A** 4WD/Shift on the fly
112 30A** Left-hand power seats
Fuse/Relay
Location
Fuse Amp
Rating
Description
113 30A** Starter motor
114 30A** Right-hand power seats
115 20A** Trailer tow battery charge
116 30A** Ignition switch
601 30A CB Door window motors
602 60A** 4-Wheel Anti-Lock Brake System
(4WABS) module
210 — Not used
211 — Not used
212 — Not used
301 — Front blower motor relay
302 — Powertrain (EEC) relay
303 — Injector driver module relay (Diesel
only)
304 — Heated backlite relay
305 — Trailer tow battery charge relay
306 — Delayed accessory relay
307 — Starter relay
* Mini Fuses ** Maxi Fuses
Jan 27, 2009 | 2002 Ford Excursion
Instruction/Owners manual for a Leisure Rangemaster 55 Auto
I have the just moved to a house with this same oven. I can't find the exact manual online, but the timer/clock seem to work the same as this one..
http://www.leisurecp.co.uk/upl/15858-GR6CV.pdf
Oct 26, 2008 | Kitchen Ranges
Car Audio & Video Logo
3,564 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
