Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Installing External Hard Drive
Having problems with installation
  • w-bobby Dec 24, 2007
    When I try to install: It trys to install ActiveX9 flashe player, a popup tells me there is a later version of ActiveX. I followed instructions and down loaded latest version. Go through the same rotine and won't install.
  • 55 Answers
Some down loads don't down load right, I would delete the player , and re download it. delete the old player before installing the new one
Posted on Jan 15, 2008
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
Have reached the limits for my hard drive Can I fit a larger hard drive other than an external unit
Yes you could, but check your specificaion to see what the maximum size hard drive the BIOS in your laptop can support.
By installing a new hard drive, you need to install Windows on this hard drive, together with the Acer Aspire's device drivers, your programs and your data. This is a lot of work and time.
If it was me I would add an external USB hard drive and copy my data to this external hard drive.
The advantages of this method besides not having to re-build your laptop, you can exchange data between computers without the need to take along your laptop, you only need to take your external USB hard drive.
Nov 28, 2010 | Acer Aspire 1690 Notebook
Hi there! Yesterday I was installing Windows XP
Sorry to hear your having issues installing the OS.
There is two problems your facing one is the disk is so scratched that the system can not read the disk or the hard drive has bad sectors or clusters which are failing when being written to.
You have two options to fix this one is to make sure the cd is clean an or replace your hard drive.
General disk read error message tend to be from hard drive cylinder's.
Nov 05, 2010 | ASUS Computers & Internet
Having saved files onto my iomega harddrive - how do i re instate files onto laptop
if the hard drive you saved the files to is separate to your laptop you can use a usb portable drive to copy these files to then plug the usb drive into your laptop to finish installing them by selecting the file right click to open
hope this helps
Sep 03, 2010 | Iomega eGo160GB External USB 2.0 Portable...
I can feel d disk rotating yet PC doesnt recognise the drive
Hi There mosam,
In most cases, external Passport Drives come with their own drivers and install themselves automatically when connected to your puter's USB port. If it doesn't find a driver, then the Passport can't work. Go to the Western Digital Support website and type in the model # of your external drive. Having located the driver for that model, download it by saving it to your desktop. Then run the exe. driver install software. Once having done so, your Passport should show right up and off you go! Very Important...if the driver install program wants you to restart your puter after installing itself, be sure to do so. Good Luck!
Apr 04, 2010 | Western Digital WD Passport 250GB Portable...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Installation problem
It means the install cannot see or detect the hard disk and is caused by :-
Incorrect BIOS setting for the hard drive.
or
A faulty hard drive.
or
The hard drive is not seated correctly on the hard drive connector.
Test the hard drive in another laptop or attach the hard drive to an USB hard drive adapter and plug it into a working computer's USB port, if it see the drive as an external drive and you can copy and delete files to this drive then it is OK and the fault is with the laptop.
Dec 29, 2008 | Compaq Presario Notebook
External hard drive not recognized
I have a WD3200 usb Hard drive. I am looking to partition it. The problem i encountered is when I go to the disk management, the drive shows up as disk one but below it , it says no media. its like the computer knows that there is an external storage device attatched but cannot access it. Also if I try to get into the disk from my computer, it says "insert disk"
Any suggestions?
-Oliver Fernandes
Sep 03, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Plugged in USB device before installing proper software
you can also inserting the cd/ dvd in rom of your laptop then it will asked the windows installation then instakk windows
May 26, 2008 | Microsoft Windows Vista Ultimate Edition
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
