Question about Health & Beauty
My four wheel travel sterling pearl seems sluggish and I have to turn the speed up to get any power just fitted new batteries any ideas
  • 1,263 Answers
Ok, try the brushes in the motor, the may be a carbon build up or they might need replacing,
Check the connections from the battery to the black or blue motor ? controller,
this is indicated by the B+ B- also check the M+ M- that goes to the motor,
Lastly is there a lot of up and down movement regarding the throttle lever or wig wam , has it come loose or is the pot worn ?
Posted on Oct 08, 2009
Pride Mobility Scooter just put in new batteries went to the shops and on the way back just stopped had to push it home not good shop is only 1Km away now it seems ok but don't want to risk it. Red li
Needs a full overnight charge of at least 12 hours and left on charge even when the lights tell you it's is charged up.then get into the habit of running it right down to improve the storage stamina of battery.good idea to take charger out with you so if you get a chance to top it up somewhere whilst away from home.remember in cold weather these things can't travel as far.
Dec 09, 2014 | Pride Mobility Victory 3 Wheel Electric...
My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
No power
The scooter has several safety cutouts, Make sure the charger is unplugged, the free-wheel shift is fully in the engaged position. Then turn the key off and back on. Make sure the speed pot is in the middle position.
Jul 06, 2012 | Shoprider Sprinter Deluxe Four Wheel...
Sluggish transmission engagement. Traveling at
changing your VSS is easy , the hardest part is finding it...look around the housing near your CV axles..the differential in there near there is a 8 or 10mm bolt holding it in witha wire connector on the end...if you pull it out you will see a plastic gear on the end of the sensor.... YOU CAN DO IT!!!!
Jun 10, 2010 | 2002 Toyota Camry
What to do if anti lock light comes on
Take the vehicle to a nearby parts store and see if they can run the code for you. most of the time its the Wheel Bearing on the front wheels of the car. The sensor is built in so you would have to replace it as an assembly. Wheel bearings and sensor related problems have always been an issue with these types of GM cars. When you get the associate to pull the Anti-Lock codes on your vehicle look to see which wheel it brings up as a fault. To further diagnose it see if you can borrow the scan tool and the associate to drive the vehicle down the road with the scan tool on the Data menu, in Anti-Lock Brakes menu. This will bring up the four wheel speed sensors as well as the transmission speed sensor. Compare the speed as you travel down the road and watch for any glitches or slower speed at one of the wheels. Dont be alarmed if the speeds are different while making a turn this is because the wheels do not travel at the same speed while turning. After you find the culprit you may replace the part as necessary.
Oct 25, 2009 | 2000 Oldsmobile Alero
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
94 buick century whenever it goes up a hill will run sluggish. When coming to a stop, will also run sluggish. Otherwise it runs well in park or at higher speeds.It happens all the time...when stopping for...
This could be a problem with your plugs or plug wires, throttle position sensor. Did you just put some new tires on? When you put tires/wheels on that are bigger than was originally on there then it can rob power from the engine. Another thing that I would check would be for vacuum leaks. Hook a vacuum gauge up to a vacuum port on the engine and read the gauge. That will give you a better idea about what is really going on vacuumwise. Hope this helps.
Jun 10, 2009 | 1994 Buick Century
There is no power
Seems like you are on the right track and you can save alot of money there. I would aproach this systematically trace the power to the switch then t0o the speed controller and back to moter you can also put some jumpers from a battery to the moter connections.
If it is in such new condition then it must be a damaged or loose connection.
Jan 21, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Sluggish on acceleration
sounds like ur injectors have them cleaned or run chevron with techron injector hope they are just dirty and not shorting out
Jun 07, 2008 | 1991 Oldsmobile Cutlass Supreme
Health & Beauty Logo
239 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
