Question about Panasonic KX-T7630 Corded Phone
How do I program numbers into the system (not personal) speed dial directory on the KX-T7630
  • Panasonic Master
  • 2,460 Answers
The installer or system manager has access to system program 001, either by a phone or by the maintenance console. All system speed dial numbers and names are entered from there.
Carl
Posted on Oct 08, 2009
How do I edit a phone number in the system directory? Regards John
The system directory sits in system program 001. It's access from the control phone, usually the first one in the system (101) and from there you press PROG **1234 and dial 001 ENTER If you keep pressing ENTER it will step through the numbers from 001 to 999, or between the first and second ENTER you can dial a 3-digit number. EXIT a few times or pick up the handset and drop it back down exits programming.
Carl
Jun 17, 2011 | Panasonic KX-T7630 Corded Phone
Can you retreive the last number of a person calling you
Using the Call Log or Directories
You can make a call with the call log or directories as follows:
Outgoing Call Log
Incoming Call Log
Extension Number Directory
System Speed Dialing Directory
Personal Speed Dialing Directory
Calling with a call log or directory
While on-hook
>Press Left or Right
until desired log/
directory appears.
>Press ENTER.
>Press Up or Down until
desired item appears.
>Off-hook
To cancel or exit, press cancel or exit.
Clearing the log information
>While confirming the log information
>Press "CLEAR".
Storing the caller's information for the Personal Speed Dialing Directory
>Press Up or
Down until
desired item
appears.
>Press STORE or
ENTER.
>Press STORE or
ENTER.
>Press "EXIT" or
PAUSE.
To enter characters, refer to "Entering Characters".
Apr 15, 2011 | Panasonic KX-T7630 Corded Phone
Changing all speed dial numbers
Speed dials reside in programming memory 001. You can change them from the maintenance console software, or an extension, usually on Jack #1, operator, or the manager's phone.
From the phone, (ext 101) press PROGRAM and dial **1234. If the display says SYS PGM then dial 001 and start with your first speed dial number (3 digit, 001-999). By stepping through the ENTER key, you will be able to find the existing numbers. A trunk access code must be the first part of a speed dial number. You probably see it as the first digit "9" in front of all your numbers.
Carl
Apr 10, 2010 | Panasonic KX-T7630 Corded Phone
Having trouble entering speed dials - please help!
Not knowing the specific model of the phone system itself (the PBX cabinet in the telephone closet) I would guess you are using the "personal directory" and it only has 10 number memory and it goes from 0-9. The system directory will give you more mems.
Sep 03, 2009 | Panasonic KX-T7730 Corded Phone
Adding/deleting a new contact to the system directory
You can download the full phone manual from Panasonic here.
Mar 26, 2009 | Panasonic KX-T7630 Corded Phone
Setting the date
By programming, these are programs 000,001 and 002 for Date and Time, Speed Dial number, and Speed Dial Name.
Date and time programming is easy, I don't wish manual speed dial entry on my worst enemy. However, if you like a challenge, I'm going to give you a link to the programming manual.
http://public.carl.airpost.net/TDA/TDA_PTPM_32.pdf
Start with page 12, since you'll need it to get into programming.
Your key sequences begin on page 16. After you put the first 5 or 10 speed dial numbers and names in, you'll get the hang of entering names in the directory. Nothing changes until you press ENTER or STORE. Each speed dial number starts with a trunk access code (usually 9) as part of the number. In name entry, each time you press the key it changes a letter. In a TDA IIRC 7 presses of the 2 key will get you ABCabc2.
Carl
Mar 19, 2009 | Panasonic KX-T7630 Corded Phone
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Changing numbers?
To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory
1.- Enter to PBX program mode from your station 101
2.- Choose program 001 to enter the quick dial numbers
3.- Choose program 002 to enter (Or change ) the Labels
Jul 05, 2008 | Panasonic KX-T7630 Corded Phone
System Directory
I assume you have the manual. I found it very difficult to follow, very poor. While "on hook" enter the number you want to call. Press "store" or "enter". Enter the name referring to the graphics chart on pages 7 & 8. It is set up for Alpha characters and it depends on which software is installed on your phone. Example: If you want the letter "A" you press the number 2 one time. If you want the number "2", you have press "2" seven times to display the number 2. Use the toggle key to move to the next letter or number you want to enter. When you have finished press "Store". It may take awhile but that's how its done. Not a very good system for the average consumer in my opinion. But that's how its done. I was unable to upload the manual. Here's the link if you don't have it: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630
Sep 10, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
897 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
