Question about Samsung Digimax S800 Digital Camera
I have lost the capability to download pictures to my PC. When I inseret the USB cable, nothing happens, it used to work fine . The green light is on ok at the other end of the cable attached to the cradle the camera is sitting in
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Oct 08, 2009
Green light on but nothing works
When the camera starts acting in a strange or unexacting way, you could "reset" it, by removing the battery for a few moments and then replace it. But be aware, the green light is on, normally, because the camera is accessing the memory card. If it can't recover from that (and the light stays on) it could be the memory card has a problem. So next to removing the battery, I should advice you to remove the memory card, and save everything on it to a computer, using an external memory card reader.
If there are no important pictures on the card, you could try to switch on again and if the camera works normal, you could try to get the pictures of the normal way with the USB cable.
If you saved all pictures to a PC, I would give the memory card a format in the camera using the setup menu, Format memory, like the manual on page 115 says.
Be aware if you only have an internal memory, you should format this and pictures in there can't be recovered.
Sep 08, 2014 | Nikon Coolpix S51c Digital Camera
Nothing happens when i plug into my usb port to download pics. green light on camera blinks is all that happens. was working fine until now
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 28, 2010 | Kodak EasyShare Z700 Digital Camera
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Hy hp d530 won't turn on
I have a similar problem:
My Compaq d530 was running fine until one day during plugging in a USB device (MP3 player) the system completely stopped working. The only thing which is active is the green LED on the mainboard.
I have checked several things and have found the following:
- IDE cable had burn marks!! (nasty)
- USB connection cable which runs from the front to the motherboard has changed in color. (darker green while all other connector have e more light white color.)
These are the signs of a brun out, but I do not have any solution to repair this.
Economically the best thing to do is buy a second hand (or new) system. (d530 are about 60 euros these days (march 2009). Hardware parts can maybe salvaged.
Dec 09, 2008 | HP Compaq d530 PC Desktop
Connecting problem
The easiest way to transfer images is to put the media card into a card reader attached to your computer.
Apr 29, 2017 | Samsung Digimax D53 Digital Camera
Photos not downloading
I tested it one more time at my home on my personal pc and it worked fine. Then when I came into work today, I pluged the USB cable into the second monitor and it worked. I have no idea why it would not work the other night. It's a mystery.
Sep 16, 2008 | Nikon D80 Digital Camera with 18-135mm...
Fuji A610 pictures will not download
look like is memory card contact problem.Try to take out the mem. card and insert in a few time.it may work.Or you can use USB card reader to download your pictures to pc.
Aug 04, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Samsung Digimax S800 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
