Question about Mitsubishi VS-50605 50" Rear Projection Television
My tv picture is just jumping and will be ok for a while then starts back
  • Mitsubishi Master
  • 8,617 Answers
You probaly need a PIP board. The vertical sync goes through the PIP module. And that model is known to have bad caps in the PIP board causing loss of vertical sync. I can give you instructions on how to bypass the PIP board to see if that is your problem . If it is if you byass the PIP with a couple 4.7uf @ 50 v capacitors your set will operate but not have PIP and its reversible if your PIP is not at fault. Let me know if you want the bypass instructions.
Posted on Feb 01, 2008
  • 48 Answers
This set is known for some very common problems some of which is just what you described. For a small fee, I can give you some common solutions that will take care of these and other issues. The only problem is you must know how to take things apart and put them back together without doing further damage, AND you must know how to solder /desolder components.
Posted on Jan 27, 2008
Picture is jumping lg55lb7500
10 Ways To Fix A TV Picture That Jumps Jerks or Skips ...
https://removeandreplace.com/.../10-ways-to-fix-a-tv-picture-that-jumps-jerks-or-skip...
Aug 5, 2016 - QUESTION: When I watch my TV, the picture sometimes jumps. How do I test it to see if it's the TV or another issue? If your TV picture is jumping while watching cable, satellite, or streaming, there are a few things you can check. See below for the best solutions to fix a TV where the picture seems to "jump" or ... Missing: lg55lb7500
Picture jumps every few seconds. - Forums - CNET
https://www.cnet.com/forums/discussions/picture-jumps-every-few-seconds-375282/ Dec 26, 2009 - 5 posts - ‎2 authors
I have a Samsung LN -T4061F model I bought two years ago. Over the past two days I have noticed that the TV picture jumps every few seconds. In the trouble sho... Picture Issue on my Samsung Television/Blu-Ray
23 Aug 2010
Samsung UN55C8000 Jumping images
7 Apr 2010
More results from www.cnet.com
Missing: lg55lb7500
How to Stop Jitter on a LCD TV ' Techwalla.com
https://www.techwalla.com/articles/how-to-stop-jitter-on-a-lcd-tv Mar 31, 2015 - When using an LCD television you may notice occasionally that the picture jitters, or jumps down the screen. This makes watching the set rather disorienting and may even cause headaches. Fortunately, there are a few troubleshooting steps you can take to correct the jittery picture issue before calling on a ... Missing: lg55lb7500
Picture jumping - The eBay Community
https://community.ebay.com/t5/Technical-Issues/Picture-jumping/td-p/26963824 In the last few days, when I have been viewing photos/pictures in a seller's listing, they have been flickering and jumping until I viewed the.Missing: lg55lb7500
Feb 21, 2018 | Televison & Video
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
I accidently pushed something on the remote to my sony wega trinitron and now it says 'no signal' I don't know how to get the picture back
You probably switched the TV from analogue to digital mode or vice-versa.
There should be a small button on your remote control marked DTV or ATV. Try pressing this.
If you are using a separate cable/satellite/tuner box from a SCART cable, turn off the tv, and turn off the cable/satellite box. Then turn the TV back on, then the cable/satellite box back on. The TV should recognise there is an external input and you should be OK.
Oct 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Apex LD3249 LCD tv.picture jumps
The tv Tuner board,that where the coalax broscast signal come in is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Jul 06, 2010 | Apex Digital LD3249 LCD TV
My 72hm195 color fades then picture jumps now i
Ur LCD inverter board it dead,U replaced this board to get picture back.It usally aa long board.
Jan 27, 2010 | Toshiba 72HM195 72" HDTV
My tv picture jumps when I walk by it. Is it the
It is EMI ... electromagnetic interference...
Do you carry your cellphone when this happens? Maybe your iPod?... could also be static charge on your clothes (not likely, but possible)... like wearing sox on a carpet...
Please comment for further help...
Sep 09, 2009 | Televison & Video
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
