Question about Nu Mark Numark Cdx Table Top CD Player CD Player
CDX keeps ejecting CDs some seconds after insertion
CDX has been working fine since it was bought about 5 yrs ago.
Never dropped, hardly moved, only used at home.
Lights up fine, resetted facory settings, but still when CDs are inserted tracks are not identified and after some seconds CD is ejected again, whether it's audio or mp3, same problem...
Replace the drive!!! I have six and this is the ONLY problem I see with these units!
Posted on Apr 08, 2010
  • Dj Enable Sep 11, 2011
    What drive would you recommend?
Why does my macbook keep ejecting CDs and DVDs out whether they are blank, burnt, or regular?
The unit is fubar and needs to be replaced since repair is not cost effective.. You might open up unit to see if there is any debris in the path of the tray that could be interfering in its operation. If all is ok,time to go shopping.
Sep 02, 2017 | Apple MacBook Pro Notebook
Hi,I have had this Pioneer CDX FM67 mounted on my bike for 5 yrs and it always played good and showed no problems.This year every time I load some cds in the player nothing happens and then I get an error...
It relates to the failure of the loading section. So check on the linking wires/flexible strip to the load motor- this is a ccommon fault and is seen most of the time.
Secondly the tray with CD can get strck due to a faulty disc- being warped. if so manually retrieve and reset.
finally there is a tiny hole near to the eject which can reset the changer if this has hung up or is jammed.
Open the covers and probe.
Jul 17, 2011 | Pioneer CDX-FM687 6-Disc CD Changer
Sony CDX-L410X Power Going To Unit But Won't Turn On
make sure you are getting power the the red (ignition ) wire.
Mar 03, 2010 | Sony CDX-L410X CD Player
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Feb 16, 2009 | Sony CDX-M730 CD Player
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Feb 17, 2008 | Sony CDX-L480X CD Player
Sony CDX - RA700
sounds like you dont have power to clock or memory wire (yellow)..also if it is a faceoff ..make sure contacts on both radio and face are clean ..
Dec 13, 2007 | Verge VMP508 CD Player
CDX-M8800 won't read CD-R discs
hi mate did you make the cd if so make the cd on slow speed it will work then max of 16x on you cd ok mate
Oct 19, 2007 | Sony CDX-M8800 CD Player
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
942 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
