Question about Hotpoint Dryers
Working one day the next not blowing hot air only warm taking ages to dry washing but will dry the make is hotpoint aquirius
  • Hotpoint Master
  • 7,482 Answers
Sounds like your problem may be with the heating coil or the thermistor/thermostats.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Check the thermistor/thermostat by removing the wires from them, tape the wires together with electrical tape and try to run the machine and see if it heats up, if it does then you need to replace the thermistor/thermostat.
DO NOT LEAVE THE WIRES TAPED TOGETHER this is dangerous, as you have no safety if the drum belt breaks, this could cause a fire.
Good Luck,
Hope this helps
Posted on Oct 08, 2009
Why does my a/c blow hot air
take it to a mechanic to get fixed. this is beyond ability of anyone to 'troubleshoot' remotely. your failure to provide make, model, age information indicates you do not have the expertise or knowledge either.
Mar 26, 2018 | Cars & Trucks
My 2002 jeep liberty blowing warm air I flash the radiator and change thermostat and still blowing warm air not hot air
Make sure that the intake is not leaking, pressurise the system and look for a leak.
Jan 06, 2015 | 2002 Jeep Liberty
Hotpoint ultima tcd980 condenser tumble dryer not drying properly
this sounds like one or two of your stats (tod) for short have gone if you need more help get back ok
Oct 22, 2012 | Washing Machines
Hotpoint Aquirius 1100 - WM63 Hi, A leak has sprung from my washing machine and being fairly capable I've already had the sump off cleaned that out and re- attached it and checked the door seal for...
Hotpoint Aquirius 1100 - WM63 leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Next Step
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Air Conditioner sometimes blows hot air once engine has warmed up
THIS AGE OF CAR ,PROBABLY NEEDS A RE CHARGE .OPEN HOOD LOOK @ THE LABELS.IF IT IS 134A YOU CAN RECHARGE IT YOURSELF PRETTY EASY.IF IT'S R12 YOU MAY NEED TO TAKE IT TO GET RETRO FITTED,
Jun 01, 2009 | 1994 Toyota Camry
I have a 1 year old Hotpoint aquirius 169s washer. The padels inside the drum keep braking and damaging our clothes. Why do they keep braking. We are not over filling the machine.
This is a commnon problem wit h some hotpoint auto m/c's. make sur you have the correct paddles as there is more than one version
Nov 18, 2008 | Hotpoint Washing Machines
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Dryers Logo
52 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
