Question about Procom QL300TYLA Heater
I want to convert a QN300TYLA natural gas unit to
I want to convert a Procom QN300TYLA natural gas stove/heater to propane. What parts need to be changed and where can I get them. Thanks, Dave
  • daltieri Oct 14, 2009
    Excellent idea, where do you live and how can I get in touch with you?
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Posted on Oct 14, 2009
    President:
  • 1,304 Answers
You will need a conversion kit
it will come with several nipples or orifices and jet covers, you may try to do it your self you can find most of what you need at the local plumbing store.
or you can call the gas company that does your service they will have the parts for purchase or install
Posted on Oct 08, 2009
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
Hello, How to convert a ProCom VentFree Stove QL300TYLA from Propane to natural gas..
yo have to get a kit the orifices are way different because nat gas runs at one half a pound and propane runa at 10 pounds
Feb 20, 2010 | Procom QL300TYLA Heater
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Nov 15, 2009 | Procom QL300TYLA Heater
I want to convert a Procom QN300TYLA natural gas stove/heater to propane. What parts are need to be changed and where can I get them? Also, I would like add a blower and remote control to control the temp...
You can't. You need an LP gas valve which costs almost as much as a new unit. Pressures are different and orifices need to be changed, the the pressure needs to be reset. Just buy a new unit and be safe.
Nov 05, 2009 | Procom QL300TYLA Heater
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Nov 06, 2008 | Heating & Cooling
Natural gas conversion
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Oct 22, 2008 | Procom ML300TBA Heater
Procom QL300TYLA Heater Logo
459 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
