Question about Canon MX700 Office All-In-One InkJet Printer
MP520 error 6A90 - printer error has occured. Manual tels me to contact serviceman!
Had the same problem with my Pixma MX700. Spoke with a technician at Canon who indicated that the error message is typically due to an issue with the cartridge casing not being able to move freely back and forth. He suggested making sure there was no packaging or tape along the track where the cartridge casing runs.
For me, there was nothing there and I could see the box run smoothly along the track and still got the error 6A90. Tried a power down, unplugging the device, and starting again - still no good.
Final solution was to bring the device to a local Canon service technician or have Canon send a box to return the device and have it replaced with a refurbished model. I'm electing to bring it to a local technician.
Fully covered since it's within one-year of purchase (need to bring proof of purchase).
Posted on Nov 27, 2009
  • 117 Answers
Before removal of the logic
board ***'y, remove the power
cord, and allow for approx. 1
minute (for discharge of
capacitor's accumulated
charges), to prevent damages
to the logic board ***'y.
Posted on Oct 08, 2009
  • surendrap915 Oct 09, 2009
    *1: The screws securing the paper feed motor may be loosened only at replacement of the paper feed motor unit.
    *2: Automatic print head alignment using the print head alignment sheet (via the operation panel only).
    (2) Periodic maintenance
    No periodic maintenance is necessary.
    (3) Periodic replacement parts
    There are no parts in this machine that require periodic replacement by a service engineer.
    (4) Replacement consumables
    There are no consumables that require replacement by a service engineer.
    Adjustment Timing Purpose Tool Approx.
    time
    EEPROM
    initialization
    At logic board replacement To initialize settings. None.
    Perform in the
    service mode.
    1 min.
    Destination settings
    (EEPROM settings)
    At logic board replacement To set the destination. None.
    Perform in the
    service mode.
    1 min.
    Ink absorber counter
    resetting
    (EEPROM settings)
    - At logic board replacement
    - At ink absorber replacement
    To reset the ink absorber counter. None.
    Perform in the
    service mode.
    1 min.
    value setting
    (EEPROM settings)
    - At logic board replacement To set the ink amount data in the ink
    absorber to the ink absorber counter.
    None.
    Perform in the
    service mode.
    1 min.
    Paper feed motor
    position adjustment*1
    At paper feed motor replacement To adjust the belt tension. (Position the
    paper feed motor so that the belt is
    stretched tight.)
    None. 5 min.
    Carriage rail position
    adjustment
    - At carriage unit replacement
    - After carriage rail removal and
    re-assembly
    To adjust the distance between the print
    head and paper (between the carriage
    and the platen).
    None. 5 min.
    Print head alignment - At print head replacement
    - When print quality is not
    satisfying
    To secure the dot placement accuracy. None. 3 min.
    (manual,
    auto*2)
    Grease application - At carriage unit or carriage rail
    replacement
    - At LF earth spring or paper
    feed roller replacement
    - At platen replacement
    To maintain sliding properties of the
    following items:
    - Carriage unit
    - LF earth spring
    - Eject roller
    FLOIL KG-107A
    IF-20
    1 min.
    Ink system function
    check
    - At spur base unit replacement
    To maintain detection functionality for
    presence of the ink tanks and each ink
    tank position.
    None.
    Perform in the
    service mode.
    1 min.
    LCD language
    settings
    At logic board replacement To set the language to be displayed on
    the LCD.
    None.
    Perform in the user
    mode.
    1 min.
    Document pressure
    sheet position
    adjustment
    - At document pressure sheet
    replacement
    - At document pressure plate
    ***'y replacement
    To adjust the pressure sheet to fit in
    place to the reference mark in the left
    back.
    None. 1 min.
    1-1
What is error code 5700?
I have seen this error a few times through the use of our inklink products.
The error 5700 is as follows:
This error takes place when feeding paper
from the ASF after an error occurred in the
ASF cam sensor.
Make sure that there is no paper jammed in the printer and nothing is blocking the paper path.
Oct 15, 2013 | Canon PIXMA MP520 InkJet Printer
Canon MP520 error message 6A80 - Have tried switching on and off at wall no help. Judy
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
May 31, 2010 | Canon MF8180C Color Laser MFC Printer
Error reading GA80 appears on screen for canon printer PRIXMA MP5
Hello Leslie,
Here is a link to the MP520 Support Page:
Canon MP520
Manuals and guides are available on the Drivers & Downloads tab.
Thaks for using Fixya.
Sep 01, 2009 | Canon Office Equipment & Supplies
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
Canon MP520 can print but not scan
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (canon), click "OSX" on the dropdown list for what os you're using, then click "mp520sosxsd1391ej7.dmg" under "MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
Feb 28, 2009 | Canon MP520 All-In-One InkJet Photo...
Canon MP520 Error 6A80 has occurred -
Hi @ all,
i got the same problem. I did some google search and found the tip below:
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
But doing this another menue appeared and i pressed okay and swithched the printer off. I did 3 times and finally the error disappeared. Now i am really happy because my printer is still working. Hope it will help you to fix your problems with this error.
Nov 03, 2008 | Canon MP520 All-In-One InkJet Photo...
Message error 6A80. Comes up with "printer error has ocurred. please turn off printer then back on again. if problem persists see manual" manual has nothing in it.
Jul 27, 2008 | Canon MP520 All-In-One InkJet Photo...
Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Apr 12, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Brand new PIXMA MP520 just connected up. Having just installed the print head and the ink cartridges, now getting message when turn on the printer. >>> 6A80 Printer error has occurred. Turn...
I opened the printer, and pushed gently on the lever that holds/releases the print head, and this seemed to release whatever was stuck. After this the print head moved freely on turning on the printer/copier.
Mar 05, 2008 | Computers & Internet
Canon MX700 Office All-In-One InkJet Printer Logo
1,083 people viewed this question
old marine
old marine
