ok well first things first laptop or desktop ? if its the same as mine you will need to try and install a older version of the driver the new one for some wicked reason will not work. try looking here http://www.broadcom.com/products/Wireless-LAN/802.11-Wireless-LAN-Solutions also have you just changed to a diffrent platform xp to vista ?or what ever ..
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
HP Pavilion 9310 calaptop, AMD64 Vista
" - petemars83
Try a few things first:
1. Make sure the card is fully seated in your machine.
2. Reboot your computer
3. Power off your system and remove the battery from your laptop for a few moments. Reinsert, boot up and try again.
4. Insert and re-insert your card.
5. Make sure you have the latest updates to your Operating System.
6. Check your Device Manager. Does it show up at all, or is there a exclamation mark? If there is nothing after you try the above steps, your card may be failing or have failed; if there is an exclamation mark, there may be a resource conflict.
If you have that exclamation mark, search your problem on Google, and try something along these lines:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1254995543174+28353475&threadId=1169082
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
does not show up in device manager @ all, tried the link, nothing either
" - petemars83
Signal strength remains excellent; speed falls from 270 to 13.5 mbps and becomes unable to even...
(More)
Signal strength remains excellent; speed falls from 270 to 13.5 mbps and becomes unable to even download homepage. Problem is intermittent. Any cure?
Getting disconnected like..every 15min(min more/less) D-Link can detect my modem without any...
(More)
Getting disconnected like..every 15min(min more/less) D-Link can detect my modem without any problems and the signal strength is at it's max-100%. What could be the problem or do You have any solutions?
when i try to connect to the internet it says something about my ip addressbeing invalid and...
(More)
when i try to connect to the internet it says something about my ip addressbeing invalid and sometimes it says something about the DNS server what can i do to fix this?
