Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Ht 1000 What kind of a computer does it take to programm the HT 1000 radio?
  • 44 Answers
I use an 486 25/50 pc running DOS. It may be possible with a slow pentium or celeron 333 or 433 mhz with Win98 booting up with a starup disk which Win98 can make for you. Whatever pc you use it will need a real com port that uses 5 volts. These old computers are getting hard to find even on junk day.
Posted on Jan 31, 2014
    Problem Solver:
  • 17 Answers
The programming software is DOS based. You can use it on a 486 computer but you need to run a programm that slows down the speed with DOS. Check out www.batlabs.com . You will find everything you need there.
Posted on Jan 10, 2008
A computer with a 286 or 386 processor
Posted on Dec 27, 2007
Samsung ht-d4500 region code
I just leave this message to tell you that this really worked for my blue ray samsung ht-f4500/zx in Mexico City. Thank you very very much. Cheers
May 02, 2012 | Samsung HT-D4500 Blu-Ray Home Theatre...
Need a user manual for ht 1000
For this concern that you're looking for the user manual for this device , you can go to this link then download the user manual save a copy of the manual to your computer or print it out for future use.
http://www.repeater-builder.com/motorola/jedi/ht1000-specs.pdf
Jan 06, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a motorola Ht 1000 i need to no how to program it with the keypad only...
The HT1000 is not keypad programmable. The HT1000 is dealer programmable using a radio interface box (RIB), cable, the appropriate Motorola propietary software. A sister radio named the JT1000 can be made keypad programmable with an accessory called a programming key.
Best regards.
Nov 29, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
I need to learn how to program my motorola HT 1000 that has a number pad on the fron.
You cannot program the radio from the DTMF keypad. The HT1000 is only programmable by an authorized dealer or person with a subscription to the software. It also requires a programming cable and RIB (radio interface box).
Jan 31, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT 1000 programming cable
Sorry to let you down, but the cable will only function with the appropriate Motorola software (and possibly a radio interface box (RIB) if the cable type you have requires one.) Software is only available to dealers. If you are needing reprogramming, it is generally available for between $25-$40 US.
Nov 17, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
Motorola HT 1000
Your radios might need reprogramming. This is done by a Motorola dealer using the appropriate cable and software. The software is not available for end-users. Cost generally is $35-$40 US.
From the information you provided, it is unclear if the radios previously worked together; or if the radios are the same model number. These are facts the dealer would be able to inquire about, and it would help them determine if your radios can talk to one another.
HT 1000 Set Scan mode
First, your radio must have one of the side buttons programmed to be scan on/off. You will need to experiment while one or more of the channels is active and press the side button to see if it puts you in scan mode.
If it is, most likely a short press turns on scan, and a long press would be nuisance channel delete. This feature will temporarily eliminate a channel out of your scan list for the time your have your radio turned on. Once you shut the unit off and turn it back on, it would return to the original setting.
The only way to have a button programmed for scan/nuisance channel delete, is to us Motorola propritary software available to dealers and certain businesses and governement agencies. If you are needing to turn on scan or change a scan list, you would need to have the radio reprogrammed. This typically will cost between $25 and $40 at more dealerships.
Oct 03, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Transmitting
read the radio on the computer and see if the TX is enabled.
Also the PA could be faulty
May 02, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Going from 1 watt to 5 watt
this feature is choosed for the programmer to be available for the user or not
You have to ask to a technitian/programmer to add this feature on your radios.
Jan 18, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Anyone have a User Manual for a HT1000?
This "switches" functions are asigned by the programmer, and depends on the systems requirments or the user habilities check with your radio programmer for any feature that you can have on your radio.
Nov 21, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
128 people viewed this question
Top Motorola Radio Communications Experts
Steve
Jose Ma DM.
Jose Ma DM.
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
