Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Wireless light is lit on router (Westell 327W) but still unable to connect wirelessly. When I go to "connect to a network" it says security-enabled network.
  • 33 Answers
You have somehow managed to enable security on your wireless (in my opinion should always be enabled) but if you dont know the passcode or want it disabled then in your web browser type '10.1.1.1' or '192.168.0.1' into the URL bar. Only one of those URL's will work.Then type your username and password (default username should be 'admin' default password should be '0000', it will say in instruction manual) then search through the configuration pages until you find the wireless security and change it accordingly. Sorry I cant give precise help because I dont have that brand of equipment, but you instruction manual should help
Posted on Oct 08, 2009
Ethernet lights 1-4 are lit, wireless light out
wireless light will be ON only if you have connected any wireless devices to your network... security light will be ON only if you enabled password to connect to your wireless network.... if you have changed any settings in the router recently, then delete the saved list of networks in the computer.... then search for wireless networks in range and connect to your network....
Apr 19, 2010 | Linksys WRT300N Wireless Router
I lost the security code for my westell 327w. need to find code so i can add another computer.
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Jan 01, 2010 | Westell Wirespeed VersaLink...
My westell versalink 327W router works when my computer is connected to it but it is not sending out a wireless signal
Try the following:
Check if wireless is enabled on the router.
Check if the wireless switch (if any) on the computer is on.
Check if the SSID broadcast is enabled.
Try a different wireless channel (6 or 11).
Hope this helps!
Nov 26, 2009 | Westell Wirespeed VersaLink...
Westell 327 router not connecting to my new Dell Laptop
So you having problem issue on the wireless router?
Try this:
1. See the icons on the down-right.
2. There'll icon with wireless connection.
3. Try to refresh it, and you'll detect you Westell router.
4. Click it twice, and you'll get connected to your wireless router.
Hope this help! Pm me if there's any questions =]
Jul 07, 2009 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
Wireless connection
Make sure the wifi capability of your laptop is turned on or enabled.
Dec 09, 2008 | Westell Wirespeed VersaLink...
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
I have a westell versalink 327w date on the bottom is 07/2007
You'll need to go into the administrative interface of the router and enable the wireless network and then you should be able to see if from any laptop/PC with a wireless networking card in it.
Feb 05, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
270 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
