Question about Freezers
Hi there my parents have a samsung cool n cool fridge freezer. the freezers the top draw doesnt keep anything frozenbut the miidle and bottom work fine. the fridge has no temperature at all and is to warm to keep anything in last night i defrosted the whole freezer when i took the panel off in the freezer i found the fan was frozen solid and when defrosted i switched it back on and it still seems it isnt working is there any advice you can give me please would be most greatful thanks
SOURCE: Left the door open on my Freezer last night and now it doesnt wor
After looking at some advice from others I turned the internal dial to the OFF position, then turned it back to 6 or 7, and left it for 20 minutes, and it is now freezing again.
Posted on Jan 05, 2009
  • 323 Answers
SOURCE: Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Posted on May 12, 2009
  • 25 Answers
SOURCE: Freezer ok, fridge not cold
Often you can unplug it overnight and it'll melt out, correcting the problem for some time.  The electric element might be burned out, although I'd suspect the defrost timer.  It's usually located behind the unit, near the bottom.  Often all you will see is a 3/4" hole in the back plate with a flat screwdriver slot.  Turn it (only turns one direction) with a flat screwdriver, and all will work fine for some time (usually).  If not, standard procedure is to replace the defrost timer assembly, as the clock motor has likely gummed up.  Maybe available at http://www.repairclinic.com, or a local appliance repair shop.  They're often generic, as in not specialty oem specific.
Posted on Jul 16, 2009
  • 389 Answers
SOURCE: brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 117 Answers
SOURCE: I have a samsung RS21DCNS fridge freezer the
HELLO THIS VIDEO IS QUITE GOOD AND MAY HELP YOU .??..#">
Posted on Sep 15, 2010
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Hi, I have a Samsung RSH1FTPE(da99-01457b) which is frosting in the fan area of the fridge so I have to defrost it manualy once a week otherwise the fridge is stopping to cool. What could be the...
please check if fan is working
if the fan doesnt work there maybe a frost problem
if the fan works its most certanly the defrost timer that doesnt work
Jun 02, 2011 | Freezers
Kenmore 106.42102301 (top refridg, bottom large freezer) water draining from cold air vent gradually building up on racks and bottom.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Kenmore Freezers
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Freezers Logo
104 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
